I am trying to install latest cyberpanel on fresh centos 7 minimal
openvz vps with command:
sh <(curl https://cyberpanel.net/install.sh || wget -O -
https://cyberpanel.net/install.sh)
The installation is failing at the point of starting pure-ftpd.
[11.25.2019_16-28-10] Running: systemctl start pure-ftpd
Job for pure-ftpd.service failed because a timeout was exceeded. See
“systemctl status pure-ftpd.service” and “journalctl -xe” for details.
[11.25.2019_16-29-40]
[11.25.2019_16-29-40] Running systemctl start pure-ftpd failed.
Running again, try number 1
[11.25.2019_16-32-41] [ERROR] We are not able to run systemctl start
pure-ftpd return code: 1. Fatal error, see /var/log/installLogs.txt
for full details.
Oops, something went wrong…
From /var/log/installLogs.txt:
[11.25.2019_16-28-07] Running: yum install -y pure-ftpd
[11.25.2019_16-28-10] Successfully ran: yum install -y pure-ftpd.
[11.25.2019_16-28-10] Running: systemctl enable pure-ftpd
[11.25.2019_16-28-10] Successfully ran: systemctl enable pure-ftpd.
[11.25.2019_16-28-10] Running: groupadd -g 2001 ftpgroup
[11.25.2019_16-28-10] Successfully ran: groupadd -g 2001 ftpgroup.
[11.25.2019_16-28-10] Running: useradd -u 2001 -s /bin/false -d
/bin/null -c “pu reftpd user” -g ftpgroup ftpuser
[11.25.2019_16-28-10] Successfully ran: useradd -u 2001 -s /bin/false
-d /bin/nu ll -c “pureftpd user” -g ftpgroup ftpuser.
[11.25.2019_16-28-10] Configuring PureFTPD…
[11.25.2019_16-28-10] Running: openssl req -newkey rsa:1024 -new
-nodes -x509 -d ays 3650 -subj
“/C=US/ST=Denial/L=Springfield/O=Dis/CN=www.example.com” -keyout
/etc/ssl/private/pure-ftpd.pem -out /etc/ssl/private/pure-ftpd.pem
[11.25.2019_16-28-10] Successfully ran: openssl req -newkey rsa:1024
-new -nodes -x509 -days 3650 -subj
/etc/ssl/private/pure-ftpd.pem -out /etc/ssl/private/pure-ftpd.pem.
[11.25.2019_16-28-10] PureFTPD configured!
pure-ftpd r eturn code: 1. Fatal error, see
/var/log/installLogs.txt for full details.
How can I fix this?
