maxin
October 20, 2019, 5:01am
#1
HI,
I have installed a wordpress and it is giving 404 on all internal links CSS and images files…
but all files existing in the corresponding path correctly,
May I know what could be the issue.
I have verified ‘Virtual Host Mappings’ is correctly mapped.
/usr/local/lsws/conf/httpd_config.conf
Please help
maxin
October 20, 2019, 5:45am
#2
Also I found another thing the name wp-content is the issue,
when I rename the folder wp-content to any other name it works .
I can access any images places inside that folder
for example
I have an images places in the following location/ link
https://example.com/wp-content/uploads/testimage.jpg ----> gives 404
and when I rename the folder wp-content to any other name say ‘mm’
https://example.com/mm/uploads/testimage.jpg -----> works fine
it works fine…
what could be the issue,
Permission and ownership everything is same… and the name with wp-contents simply not working
anyone can help out of this ?
Thanks…
did you check your permalinks and htaccess rewrites?
did you try this is in another browser and/or clear your browser cache and cookies?
the other thing I can think of is something like a plugin that maybe protects this folder if named that or if you exceeded the Litespeed Enterprise license domain limit and its maybe blocking that?
maxin
October 21, 2019, 4:16am
#6
no, I’m using openlitespeed… I has tried from different browser its not a cache issue…
anyway let me try something…
