I have an installation failure as well on CentOS VirtualBox Windows
Transaction Summary
Install 2 Packages (+2 Dependent packages)
Total download size: 3.4 M
Installed size: 12 M
Downloading packages:
(1/4): luajit-2.0.4-3.el7.x86_64.rpm | 343 kB 00:00
(2/4): pdns-backend-mysql-0.0.2401g849c452-1pdns.el7.x86_6 | 38 kB 00:00
(3/4): libsodium-1.0.16-1.el7.x86_64.rpm | 140 kB 00:00
(4/4): pdns-0.0.2401g849c452-1pdns.el7.x86_64.rpm | 2.9 MB 00:01
Total 2.1 MB/s | 3.4 MB 00:01
Running transaction check
Running transaction test
Transaction test succeeded
Running transaction
Installing : luajit-2.0.4-3.el7.x86_64 1/4
Installing : libsodium-1.0.16-1.el7.x86_64 2/4
Installing : pdns-0.0.2401g849c452-1pdns.el7.x86_64 3/4
Installing : pdns-backend-mysql-0.0.2401g849c452-1pdns.el7.x86_64 4/4
Verifying : pdns-backend-mysql-0.0.2401g849c452-1pdns.el7.x86_64 1/4
Verifying : libsodium-1.0.16-1.el7.x86_64 2/4
Verifying : luajit-2.0.4-3.el7.x86_64 3/4
Verifying : pdns-0.0.2401g849c452-1pdns.el7.x86_64 4/4
Installed:
pdns.x86_64 0:0.0.2401g849c452-1pdns.el7
pdns-backend-mysql.x86_64 0:0.0.2401g849c452-1pdns.el7
Dependency Installed:
libsodium.x86_64 0:1.0.16-1.el7 luajit.x86_64 0:2.0.4-3.el7
Complete!
[11-19-38-Mon-Aug-2018] #########################################################################
[11-19-38-Mon-Aug-2018] PowerDNS successfully installed!
[11-19-38-Mon-Aug-2018] Configuring PowerDNS…
[11-19-38-Mon-Aug-2018] PowerDNS configured!
Created symlink from /etc/systemd/system/multi-user.target.wants/pdns.service to /usr/lib/systemd/system/pdns.service.
[11-19-39-Mon-Aug-2018] #########################################################################
[11-19-39-Mon-Aug-2018] PowerDNS successfully enabled at system restart!
Job for pdns.service failed because the control process exited with error code. See “systemctl status pdns.service” and “journalctl -xe” for details.
[11-19-39-Mon-Aug-2018] Trying to start PowerDNS instance, trying again, try number: 2
[11-19-41-Mon-Aug-2018] #########################################################################
[11-19-41-Mon-Aug-2018] Trying to start PowerDNS instance, trying again, try number: 3
[11-19-41-Mon-Aug-2018] Installation failed, consult: /var/log/installLogs.txt
CyberPanel installation failed.
