Provider: Digital Ocean
Virtualization Type: Droplet
System: CentOS 8.1x64 1vcpu 2GB 50GB
Installation option: Install CyberPanel
OLS or Enterprise?
Enterprise
official
yes
Install LiteSpeed Memcached?
yes
Install Memcached?
yes
yes
Install Redis?
yes
Problem:
Followed the installation guide. Installed LiteSpeed Server Enterprise using valid serial number. Installs. When I try to go to login - ServerIP:8090 I’m getting a 503 Service Unavailable The server is temporarily busy, try again later!
I’ve checked to see if LSCPD is running using - systemctl status lscpd which is showing as active.
Also tried the steps in Manually set up virtualenv but to no avail.
Further to my initial bug report. When carrying out the steps in Manually Set up virtualenv I get the following:
virtualenv --system-site-packages /usr/local/CyberCP results in
Using base prefix ‘/usr’
No LICENSE.txt / LICENSE found in source
New python executable in /usr/local/CyberCP/bin/python3.6
Not overwriting existing python script /usr/local/CyberCP/bin/python (you must use /usr/local/CyberCP/bin/python3.6)
File “/usr/local/bin/virtualenv”, line 11, in
sys.exit(main())
File “/usr/local/lib/python3.6/site-packages/virtualenv.py”, line 870, in main
symlink=options.symlink,
File “/usr/local/lib/python3.6/site-packages/virtualenv.py”, line 1162, in create_environment
install_python(home_dir, lib_dir, inc_dir, bin_dir, site_packages=site_packages, clear=clear, symlink=symlink)
File “/usr/local/lib/python3.6/site-packages/virtualenv.py”, line 1691, in install_python
raise e
File “/usr/local/lib/python3.6/site-packages/virtualenv.py”, line 1683, in install_python
proc = subprocess.Popen(cmd, stdout=subprocess.PIPE)
File “/usr/lib64/python3.6/subprocess.py”, line 729, in init
restore_signals, start_new_session)
File “/usr/lib64/python3.6/subprocess.py”, line 1364, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
OSError: [Errno 40] Too many levels of symbolic links: ‘/usr/local/CyberCP/bin/python3.6’
Then when I try: systemctl restart gunicorn.socket I get
Failed to restart gunicorn.socket: Unit gunicorn.socket not found.
Hi thanks for replying.
I’m using Digital Ocean and created the following:
CentOS 8.1 x64
1 VCPU 2GB RAM 50GB Space
If I type in my Droplet IP I get the LiteSpeed Congratulations page but only over http not https://
if I try and add 8090 I get the 503 page
It is recommended for Centos 7.x
