Increase LSAPI_CHILDREN
I see the following in my stderr.log hundreds of times.
[7768] Reached max children process limit: 5, extra: 1, current: 6, busy: 6, please increase LSAPI_CHILDREN.
so I would like to increase my LSAPI_CHILDREN.
My website’s vHost conf doesn’t contain any line with LSAPI_CHILDREN, is there any other location I can check?
PS: I’m using CyberPanel Enterprise 1.8.1
Thanks,
George
Hello
If on the command line you do
cat /usr/local/lsws/conf/httpd_config.xml | grep LSAPI_CHILDREN
You will see value of PHP_LSAPI_CHILDREN. You can open this file via nano or vi editor and edit this parameter and restart LiteSpeed, you can also do this via Webadmin. An example of output of the above command is
      <env>PHP_LSAPI_CHILDREN=35</env>
there is also a parameter
phpSuExecMaxConn>5</phpSuExecMaxCon
in httpd_config.xml
need to change 5 to higher number.
Thanks, it was phpSuExecMaxConn after all :wink:
