Basically at least 2 errors keeps coming every minute;
ERROR [238728] [T0] [/usr/local/lsws/conf/vhosts/{[somedomain.com](http://somedomain.com/)}/vhost.conf:33] Listener for *default* is not available.
[[Sun Feb 6 21:39:02 2022] [notice] Finish reading Apache configuration, server configured โ resuming normal operations
After that;
i changed setting not to read httpd.conf
i made new virtualhost from menu with the help of template (there was none) and it make a new xml file.
i made 4 listener from menu (there was none)
After restart errors gone, website live again. in the servicemgr screen there is a 1 domain host.
But now still;
Litespeed server keeps restarting EVERY MINUTE
Every restart new error.log file have been created also (8Kbyte)
HERE IS LOG
2022-02-09 15:18:43.261787 [NOTICE] [96123] [T0] Litespeed is ready to serve...
2022-02-09 15:18:43.262362 [NOTICE] [96123] [T0] [AutoRestarter] new child process with pid=96126 is forked!
2022-02-09 15:18:43.263582 [INFO] [96126] [T0] registered RT signal 38
2022-02-09 15:18:43.263630 [INFO] [96126] [T0] [UDP 0.0.0.0:443] initPacketsIn: allocated 100 packets
2022-02-09 15:18:43.263703 [INFO] [96126] [T0] [UDP [::]:443] initPacketsIn: allocated 100 packets
2022-02-09 15:18:43.264154 [NOTICE] [96126] [T0] [Child: 96126] Setup swapping space...
2022-02-09 15:18:43.264212 [NOTICE] [96126] [T0] Successfully change current user to nobody
2022-02-09 15:18:43.264219 [NOTICE] [96126] [T0] Core dump is enabled.
2022-02-09 15:18:43.264627 [INFO] [96126] [T0] [SSL_APK] created offloader with 1 workers.
2022-02-09 15:18:43.264737 [INFO] [96126] [T0] [MODSEC] created offloader with 10 workers.
2022-02-09 15:18:43.264846 [INFO] [96126] [T0] [MODSEC_BODY] created offloader with 50 workers.
2022-02-09 15:18:43.264850 [ALERT] [96126] [T0] LiteSpeed/6.0 Enterprise starts successfully!
2022-02-09 15:18:43.268951 [NOTICE] [96048] [T0] New litespeed process is ready, stops listeners
2022-02-09 15:18:43.269002 [INFO] [96048] [T0] Stop all listeners.
2022-02-09 15:18:43.269016 [INFO] [96048] [T0] Stop listener *:80.
2022-02-09 15:18:43.269024 [INFO] [96048] [T0] Stop listener [::]:80.
2022-02-09 15:18:43.269031 [INFO] [96048] [T0] Stop listener *:443.
2022-02-09 15:18:43.269035 [INFO] [96048] [T0] Stop listener [::]:443.
2022-02-09 15:18:43.269038 [INFO] [96048] [T0] Stop listener *:7080.
2022-02-09 15:18:43.269045 [NOTICE] [96048] [T0] QuicEngine::startCoolDown(), active connections: 0
2022-02-09 15:18:48.171247 [INFO] [96126] [T0] [etfiy6678] add child process pid: 96137, procinfo: 0x23dc420
2022-02-09 15:20:17.971229 [NOTICE] [96123] [T0] [96123] Server Restart Request via Signal...
2022-02-09 15:20:17.973316 [INFO] [96123] [T0] Stop all listeners.
2022-02-09 15:20:17.973381 [INFO] [96123] [T0] Stop listener *:80.
2022-02-09 15:20:17.973416 [INFO] [96123] [T0] Stop listener [::]:80.
2022-02-09 15:20:17.973439 [INFO] [96123] [T0] Stop listener *:443.
2022-02-09 15:20:17.973461 [INFO] [96123] [T0] Stop listener [::]:443.
2022-02-09 15:20:17.973476 [INFO] [96123] [T0] Stop listener *:7080.
2022-02-09 15:20:17.973494 [NOTICE] [96123] [T0] Stop all children workers, nowait=0
2022-02-09 15:20:17.973852 [NOTICE] [96123] [T0] Forked [96194] for graceful restart.
2022-02-09 15:20:17.973891 [NOTICE] [96123] [T0] Start passing listener sockets through forked child [96194].
2022-02-09 15:20:17.973923 [INFO] [96194] [T0] [*:7080] Pass listener, copy fd 15 to 1006.
2022-02-09 15:20:17.973949 [INFO] [96194] [T0] [UDP [::]:443] pass listener, copy fd 14 to 1005.
2022-02-09 15:20:17.973960 [INFO] [96194] [T0] [[::]:443] Pass listener, copy fd 13 to 1004.
2022-02-09 15:20:17.973968 [INFO] [96194] [T0] [UDP *:443] pass listener, copy fd 12 to 1003.
2022-02-09 15:20:17.973974 [INFO] [96194] [T0] [*:443] Pass listener, copy fd 11 to 1002.
2022-02-09 15:20:17.973980 [INFO] [96194] [T0] [[::]:80] Pass listener, copy fd 10 to 1001.
2022-02-09 15:20:17.974007 [INFO] [96194] [T0] [*:80] Pass listener, copy fd 9 to 1000.
2022-02-09 15:20:17.974031 [NOTICE] [96194] [T0] Starting new instance: execute '/usr/local/lsws/bin/litespeed'.
2022-02-09 15:20:17.972139 [NOTICE] [96126] [T0] killed by SIGINT!
2022-02-09 15:20:17.972177 [NOTICE] [96126] [T0] Start shutting down gracefully ...
2022-02-09 15:20:17.972207 [NOTICE] [96126] [T0] Event-loop lingering start.
2022-02-09 15:20:18.383592 [NOTICE] [96123] [T0] [AutoRestarter] cleanup children processes and unix sockets of process with pid=96126 !
2022-02-09 15:20:18.383626 [NOTICE] [96123] [T0] [AutoRestarter] child process with pid=96126 exited with status=0!
2022-02-09 15:20:18.383715 [NOTICE] [96123] [T0] Main server stopped!
