I Need help please?
You mentioned the firewall.
Can you check if you have the firewall disabled for IPv6?
If so, can you enable it for IPv6 and check if it is now sent correctly?
By default, the mail server is set up to use down ipv4 and ipv6, so it may be trying to send by ipv6.
Ipv6 = on
Ipv6_icmp_strict = off
Ipv6_spi = on
These are the settings
Check if you also have:
SMTP_BLOCK = OFF
at CSF configuration.
If yes, message me tomorrow between 12 and 00 UTC to take a look by anydesk
SMTP_BLOCK = OFF
Yes
Can we choose a later time?
Message me when you can, i will be online for the next 8h
Until now
I didn’t find any solutions
I did that and the problem is still there
if you don’t send logs, nobody can help you.
What records do you want to send?
Share complete mail logs?
Where do I find the file?
leadership issue found
Issue: Email server trying to send by ipv6, but VPS didn’t support ipv6.
Solution: Disable ipv6 by doing the following steps:
1 - Edit the file
/etc/postfix/main.cf
2 - Look for:
inet_protocols = all
3 - Change into:
inet_protocols = ipv4
4 - Restart postfix:
systemctl restart postfix
so ipv6
Unable to send or must be specified in the file
I want to thank you my friend
To solve the problem and please create a video explanation so that all subscribers can benefit
