Hi i want to remove custom SSL which expired and i do not want to renew, how can i do that on cyberpanel?
I want to install Let’s Encrypt SSL instead of the custom one.
just click on SSL—> Manage SSL ----> Choose your website
There is only Issue SSL button on there? I want to remove the custom SSL.
that will install LE SSL and your custom will removed
but if you want to replace your custom to LE… you can just add LE
Maybe try to login to litespeed yourIp:7080 and look virtual host your domain and look SSL you see location of SSL remove that or delete keys from that location.
