If you want to merge and combine two PST files, then MailsDaddy PST merge and join tool is the perfect solution to combine the two and more PST files. This tool helps you to merge the two PST files without any hassle. And join PST files easily. While adding two PST files in this attractive tool, if you want the data of both of them to be in different folders, this tool also provides this facility. If you want all the data to be saved in the same folder, then with the help of this tool, you can do the same.
For More Information- combine PST files
