ClosedHow to fix dkim fail domain
I have noticed when use cloudflare need to remove " from dkim see below not sure if you use cyberpanel dns never try that.
Cyber panel give DKIM
"v=DKIM1; h=sha256; k=rsa; "
“p=MIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAxSEgSm+V2sI8alDrFlySTjz6wZh+xUJVqnqJ6UTfUm8dkY1LKPeOINPlGFnT9ugxdK4XvJuVh22mig/L5xCoP70M8IeNTfNcCjWgNhtsB5m2mV1V3U6jg//F0Cvs5Zq+eZISEYmMO4L/xZZtjJkS4bewthtnedfdbsfe2ht34w5jkekm/BTmaXkC3hJ3pe0Rm7szI0V2RBYngg”
“JQF8ChNmoxufDPGtReGclfEW+zvx1qerrevregegEuE41t65Z24vvDujK/xJNEiZNsCK058lnZDaM8n2y7FEWOPSHw1pxGZLIvFPSkMQCIfnHlKxOP7AxoXNhbh9FysQWftIJV9WOwIDAQAB”
and after removing
When you are using CLoudFlare then make sure while adding DKIM remove all " signs and then add
to get straight to gmail inbox
