when i click phpmyadmin from the control panel it automatically login in phpmyadmin but when i am logout of cyberpanel and access from url www.abc.com:8090/phpmyadmin
it becomes white screen and does not ask login details how to fix this issue. i want to it to ask login details.
Direct access via link is restricted and not available for security reasons. If you need users to access phpmyadmin, then create new user account inside cyberpanel. Using the new user login credentials, the user can login to cyberpanel and access phpmyadmin (it will display database of sites which are created under that user)
