Dear sirs,
Where can I modify/delete ns records created via DNS >> create nameserver?
What I did:
- main >> website >> create website
- main >> DNS >> create nameserver
I went to the created website >> manage >> added a domain.
I uploaded an index file onto the subdomain >> public_dir and YES, subdomain resolves, etc.
Sample file uploaded into the the domain >> public_dir; main domain also resolves fine.
Now trying to setup a mailserver, followed this tutorial: How to Host Your Own Email Server (with CyberPanel) - Tony Teaches Tech
section 4B also says to create nameserver
My mailserver is up and running, however I just discovered that the IP assigned is blacklisted.
I have modified the IPs that my registered domains ns1 and ns2 are pointing to - at the domain registrar panel,
Now I need to make the necessary changes in Cyberpanel.
I have checked DNS >> add/delete records >> select domain >> NS tab… however there are no records listed there.
Pls help / clarify
regards
Tokunbo
