Hi, clients on my server have a link to email management through which they can connect to Rainloop (IP:8090/rainloop). According to the latest CyberPanel update ( v2.3.2 - Replace Rainloop with SnappyMail) Rainloop is removed and SnappyMail is used in its place, after this update the link (IP:8090/rainloop) no longer works (Not Found). What should be done to redirect customers using the old link (IP:8090/rainloop) to the new link (IP:8090/snappymail) ?
Figure it out myself. Solution:
In folder (in CentOS) /usr/local/CyberCP/public create new folder rainloop and add index.php file with this content:
<?php header("Location: YOUR IP OR MAIL DOMAIN:8090/snappymail/"); die(); ?>the funny thing when i created this folder i found it full with files and folders ! i deleted all these files and folders anyway
