Hi, I have a domain created, but I need to create a folder inside and that folder has a WordPress in it.
I need this domain .com/folder/
I don’t want a subdomain, I need is a folder inside the root domain and put another WordPress inside with other content.
How do I do it with Cyberpanel?
Thank you.
Go to file manager click on public_html then at the top of the page click on new folder
And I can put another WordPress without problem in there?
You can even do that using the default WordPress installer in CyberPanel. During installation just use the path box and specify the path you want WordPress installation in.
Thanks!!!
