How to change IP inside Panel
InkedCapture_LI
any idea on how to change this ip address ? to our domain name
I my understanding you cant.
You want you can change panel URL to your own domain.
/usr/local/CyberCP/baseTemplate/templates/baseTemplate >index.html
You can edit it there.
Capture
after edit.
:thinking: That edit will quite likely wipe out when you update panel. You kind of cropped out that edit from your image too…
