[ERROR] Compress with both Brotli and Gzip turned off
Found on:
ERROR LOGS
Error Logs for main web server.
This means the options are turned off and you will need to turn them on to remove the error.
Where to turn on Brotli?
I can only see the settings for Gzip and it’s already on.
I’m also experiencing this error
