I am using CyberPanel (OpenLiteSpeed ) on CentOS 7, when I am trying to update through Terminal Command then an error message comes and is as:
[root@server ~]# yum update -y
Loaded plugins: fastestmirror Loading mirror speeds from cached hostfile epel/x86_64/metalink | 7.6 kB 00:00:00
base: repo1.dal.innoscale.net
epel: d2lzkl7pfhq30w.cloudfront.net
extras: mirror.cs.vt.edu
updates: mirror.atlanticmetro.net https://rep.cyberpanel.net/repodata/repomd.xml: [Errno 14] curl#60 - "Peer's Certificate has expired." Trying other mirror. It was impossible to connect to the CentOS servers. This could mean a connectivity issue in your environment, such as the requirement to configure a proxy, or a transparent proxy that tampers with TLS security, or an incorrect system clock. You can try to solve this issue by using the instructions on https://wiki.centos.org/yum-errors If above article doesn't help to resolve this issue please use https://bugs.centos.org/.
One of the configured repositories failed (CyberPanel), and yum doesn’t have enough cached data to continue. At this point the only safe thing yum can do is fail. There are a few ways to work “fix” this:
Contact the upstream for the repository and get them to fix the problem.
Reconfigure the baseurl/etc. for the repository, to point to a working upstream. This is most often useful if you are using a newer distribution release than is supported by the repository (and the packages for the previous distribution release still work).
Run the command with the repository temporarily disabled yum --disablerepo=CyberPanel ...
Disable the repository permanently, so yum won't use it by default. Yum will then just ignore the repository until you permanently enable it again or use --enablerepo for temporary usage:
yum-config-manager --disable CyberPanel or subscription-manager repos --disable=CyberPanel
Configure the failing repository to be skipped, if it is unavailable. Note that yum will try to contact the repo. when it runs most commands, so will have to try and fail each time (and thus. yum will be be much slower). If it is a very temporary problem though, this is often a nice compromise:
yum-config-manager --save --setopt=CyberPanel.skip_if_unavailable=true
failure: repodata/repomd.xml from CyberPanel: [Errno 256] No more mirrors to try. https://rep.cyberpanel.net/repodata/repomd.xml: [Errno 14] curl#60 - “Peer’s Certificate has expired.”
[root@server ~]#
As well when I am running this Command to get repolist, then:
[root@server ~]# yum repolist
repo id
base/7/x86_64
copr:copr.fedorainfracloud.org:copart:restic/x86_64
dovecot-2.3-latest/7/x86_64
epel/x86_64
extras/7/x86_64
gf/x86_64
litespeed/7/x86_64
litespeed-update/7/x86_64
lux/7
mariadb
powerdns-auth-42/7/x86_64
updates/7/x86_64
repolist: 29,666
How can I delete it, actually I new with Terminal command’s & need the correct Terminal Command through which I can delete it.
Truly Can I use: yum remove CyberPanel or any other. Please help me.
Thanks
