Retrying (Retry(total=4, connect=None, read=None, redirect=None)) after connection broken by ‘ReadTimeoutError(“HTTPSConnectionPool(host=‘pypi.org’, port=443): Read timed out. (read timeout=15)”,)’: /simple/django/
pls help
pls help
Collecting django==1.11
Retrying (Retry(total=3, connect=None, read=None, redirect=None)) after connection broken by ‘ReadTimeoutError(“HTTPSConnectionPool(host=‘pypi.org’, port=443): Read timed out. (read timeout=15)”,)’: /simple/django/
Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by ‘ReadTimeoutError(“HTTPSConnectionPool(host=‘pypi.org’, port=443): Read timed out. (read timeout=15)”,)’: /simple/django/
Retrying (Retry(total=1, connect=None, read=None, redirect=None)) after connection broken by ‘ReadTimeoutError(“HTTPSConnectionPool(host=‘pypi.org’, port=443): Read timed out. (read timeout=15)”,)’: /simple/django/
Retrying (Retry(total=0, connect=None, read=None, redirect=None)) after connection broken by ‘ReadTimeoutError(“HTTPSConnectionPool(host=‘pypi.org’, port=443): Read timed out. (read timeout=15)”,)’: /simple/django/
Could not find a version that satisfies the requirement django==1.11 (from versions: )
No matching distribution found for django==1.11
Provide these details here : Bug Report Template — CyberPanel - WebHosting Control Panel for OpenLiteSpeed
Package python-setuptools-0.9.8-7.el7.noarch already installed and latest version
Nothing to do
[09-31-48-Mon-Dec-2018] Python setup tools Successfully installed!
Retrying (Retry(total=4, connect=None, read=None, redirect=None)) after connection broken by ‘ReadTimeoutError(“HTTPSConnectionPool(host=‘pypi.python.org’, port=443): Read timed out. (read timeout=15)”,)’: /simple/django/
File “install.py”, line 3647, in
main()
Operation cancelled by user
again problem
django fail
