[root@cyberpanel-02 ~]# systemctl status gunicorn.socket
● gunicorn.socket - gunicorn socket
Loaded: loaded (/etc/systemd/system/gunicorn.socket; enabled; vendor preset: disabled)
Active: failed (Result: resources)
Listen: 127.0.0.1:5003 (Stream)
Kas 15 18:16:15 cyberpanel-02 systemd[1]: Starting gunicorn socket.
Kas 15 18:19:50 cyberpanel-02 systemd[1]: gunicorn.socket failed to listen on sockets: No such file or directory
Kas 15 18:19:50 cyberpanel-02 systemd[1]: Failed to listen on gunicorn socket.
Kas 15 18:19:50 cyberpanel-02 systemd[1]: Starting gunicorn socket.
Kas 15 18:25:37 cyberpanel-02 systemd[1]: gunicorn.socket failed to listen on sockets: No such file or directory
Kas 15 18:25:37 cyberpanel-02 systemd[1]: Failed to listen on gunicorn socket.
Kas 15 18:25:37 cyberpanel-02 systemd[1]: Starting gunicorn socket.
Kas 15 18:26:02 cyberpanel-02 systemd[1]: gunicorn.socket failed to listen on sockets: No such file or directory
Kas 15 18:26:02 cyberpanel-02 systemd[1]: Failed to listen on gunicorn socket.
Kas 15 18:26:02 cyberpanel-02 systemd[1]: Starting gunicorn socket.
source /usr/local/CyberCP/bin/activate
pip install --ignore-installed -r /usr/local/CyberCP/requirments.txt
deactivate
virtualenv --system-site-packages /usr/local/CyberCP
systemctl restart gunicorn.socket
none of this works!
/var/log/installLogs.txt
print error log >>
[05-39-02-Thu-Nov-2018] Project dependant modules installed successfully!
[05-39-03-Thu-Nov-2018] virtualenv installed successfully!
[05-39-06-Thu-Nov-2018] virtualenv setuped successfully!
[05-39-25-Thu-Nov-2018] Failed to install project dependant modules! [setupVirtualEnv]
[05-39-29-Thu-Nov-2018] CyberPanel installation successfully completed!
[06-11-50-Thu-Nov-2018] Starting CyberPanel installation…
Provider >> DigitalOcean, Aws, Gcloud and VMware
