I’m trying to add a Google Drive Backup account, but the option is redirecting me to https://cloud.cyberpanel.net/ instead.
I have tried to clear cache, reinstall CyberPanel but it’s still not working.
Kindly assist.
Kindly assist.
same here…
As I found in the docs, there used to be a problem:
Troubleshooting redirection from platform to cloud
We have recently shifted the support URL from platform.cyberpanel.net to cloud.cyberpanel.net. If you are being redirected and unable to setup, please upgrade Cyberpanel and try again
However, this was not fixed for me after an the upgrade
hello, im having the same problem.
“error_message”: “No module named ‘google’”,
can we please get a response on this?
@deewinc @j2ee
FYI… I use the following command now (with the combination of cronjob):
cyberpanel createBackup --domainName
The backups will be created in the default location:
/home//backup
From there I upload the backups manually to google drive.
I can recommand this guide:
MAYBE this issue will be fixed eventually from cyberpanel…
Cheers
we need an internal solution in cyberpanel
Solution is internal, I’ve explained couple of times that google oauth need a valid domain and that process require you to move to cloud.cyberpanel.net, after that process is all in CyberPanel.
This was not clear in the docs , I appreciate your work and help .
