Hello, I today noticed that my error logs generating many data. for rewrite. How i can resolve it?
2022-07-23 16:30:24.471728 [INFO] [57587] [172.70.135.166:48252:HTTP2-1#abiti.lt] [REWRITE] add ENV: ‘HTTP_AUTHORIZATION:’
2022-07-23 16:30:24.471753 [INFO] [57587] [172.70.135.166:48252:HTTP2-1#abiti.lt] [REWRITE] No substition
2022-07-23 16:30:24.471763 [INFO] [57587] [172.70.135.166:48252:HTTP2-1#abiti.lt] [REWRITE] Rule: Match ‘produkto-zyma/pilki-dzinsai/’ with pattern ‘^index.php$’, result: -1
2022-07-23 16:30:24.471772 [INFO] [57587] [172.70.135.166:48252:HTTP2-1#abiti.lt] [REWRITE] Rule: Match ‘produkto-zyma/pilki-dzinsai/’ with pattern ‘^en/wp-login.php’, result: -1
2022-07-23 16:30:24.471780 [INFO] [57587] [172.70.135.166:48252:HTTP2-1#abiti.lt] [REWRITE] Rule: Match ‘produkto-zyma/pilki-dzinsai/’ with pattern ‘^lt/wp-login.php’, result: -1
2022-07-23 16:30:24.471790 [INFO] [57587] [172.70.135.166:48252:HTTP2-1#abiti.lt] [REWRITE] Rule: Match ‘produkto-zyma/pilki-dzinsai/’ with pattern ‘.’, result: 1
2022-07-23 16:30:24.471847 [INFO] [57587] [172.70.135.166:48252:HTTP2-1#abiti.lt] [REWRITE] stat( /home/abiti.lt/public_html/produkto-zyma ) failed
2022-07-23 16:30:24.471867 [INFO] [57587] [172.70.135.166:48252:HTTP2-1#abiti.lt] [REWRITE] stat( /home/abiti.lt/public_html/produkto-zyma ) failed
2022-07-23 16:30:24.471883 [INFO] [57587] [172.70.135.166:48252:HTTP2-1#abiti.lt] [REWRITE] Source URI: ‘produkto-zyma/pilki-dzinsai/’ => Result URI: ‘/index.php’
2022-07-23 16:30:24.471897 [INFO] [57587] [172.70.135.166:48252:HTTP2-1#abiti.lt] [REWRITE] Last Rule, stop!
2022-07-23 16:30:24.471909 [INFO] [57587] [172.70.135.166:48252:HTTP2-1#abiti.lt] [REWRITE] apply cache-control: ‘no-autoflush’.
2022-07-23 16:30:27.447102 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] strip base: ‘/’ from URI: ‘/produkto-zyma/pilki-dzinsai/’
2022-07-23 16:30:27.447189 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] Rule: Match ‘produkto-zyma/pilki-dzinsai/’ with pattern ‘^/?(.)', result: 2
2022-07-23 16:30:27.447209 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] Cond: Compare ‘on’ with pattern ‘on’, result: 0
2022-07-23 16:30:27.447224 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] Rule: Match ‘produkto-zyma/pilki-dzinsai/’ with pattern '.’, result: 1
2022-07-23 16:30:27.447241 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] No substition
2022-07-23 16:30:27.447256 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] Rule: Match ‘produkto-zyma/pilki-dzinsai/’ with pattern ‘.litespeed_conf.dat’, result: -1
2022-07-23 16:30:27.447270 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] Rule: Match ‘produkto-zyma/pilki-dzinsai/’ with pattern ‘.', result: 1
2022-07-23 16:30:27.447290 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] Cond: Match ‘Mozilla/5.0 (compatible; SemrushBot/7~bl; +http://www.semrush.com/bot.html)’ with pattern ‘Mobile|Android|Silk/|Kindle|BlackBerry|Opera\ Mini|Opera\ Mobi’, result: -1
2022-07-23 16:30:27.447299 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] Rule: Match ‘produkto-zyma/pilki-dzinsai/’ with pattern 'wp-content/./[^/](responsive|css|js|dynamic|loader|fonts).php’, result: -1
2022-07-23 16:30:27.447307 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] Rule: Match ‘produkto-zyma/pilki-dzinsai/’ with pattern ‘.?’, result: 1
2022-07-23 16:30:27.447317 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] set cache vary on: ‘,wp-postpass_dc0b5078bedd01200fbf729e7d76bd4f’
2022-07-23 16:30:27.447343 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] add ENV: ‘Cache-Vary:,wp-postpass_dc0b5078bedd01200fbf729e7d76bd4f’
2022-07-23 16:30:27.447351 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] No substition
2022-07-23 16:30:27.447358 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] Rule: Match ‘produkto-zyma/pilki-dzinsai/’ with pattern ‘favicon.ico$’, result: -1
2022-07-23 16:30:27.447367 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] Rule: Match ‘produkto-zyma/pilki-dzinsai/’ with pattern '.’, result: 1
2022-07-23 16:30:27.447377 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] Cond: Match ‘text/html, application/rss+xml, application/atom+xml, text/xml, text/rss+xml, application/xhtml+xml’ with pattern ‘image/webp’, result: -1
2022-07-23 16:30:27.447415 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] Cond: Match ‘Mozilla/5.0 (compatible; SemrushBot/7~bl; +http://www.semrush.com/bot.html)’ with pattern ‘Page Speed’, result: -1
2022-07-23 16:30:27.447424 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] Rule: Match ‘produkto-zyma/pilki-dzinsai/’ with pattern ‘.*’, result: 1
2022-07-23 16:30:27.447432 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] Cond: Match ‘Mozilla/5.0 (compatible; SemrushBot/7~bl; +http://www.semrush.com/bot.html)’ with pattern ‘iPhone.*Version/(\d{2}).Safari’, result: -1
2022-07-23 16:30:27.447441 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] Rule: Match ‘produkto-zyma/pilki-dzinsai/’ with pattern ‘^’, result: 1
2022-07-23 16:30:27.447470 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] No substition
2022-07-23 16:30:27.447479 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] Rule: Match ‘produkto-zyma/pilki-dzinsai/’ with pattern ‘^’, result: 1
2022-07-23 16:30:27.447489 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] No substition
2022-07-23 16:30:27.447496 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] Rule: Match ‘produkto-zyma/pilki-dzinsai/’ with pattern ‘^’, result: 1
2022-07-23 16:30:27.447505 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] No substition
2022-07-23 16:30:27.447513 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] Rule: Match ‘produkto-zyma/pilki-dzinsai/’ with pattern ‘^’, result: 1
2022-07-23 16:30:27.447522 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] No substition
2022-07-23 16:30:27.447530 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] Rule: Match ‘produkto-zyma/pilki-dzinsai/’ with pattern '.’, result: 1
2022-07-23 16:30:27.447540 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] add ENV: ‘HTTP_AUTHORIZATION:’
2022-07-23 16:30:27.447547 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] No substition
2022-07-23 16:30:27.447555 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] Rule: Match ‘produkto-zyma/pilki-dzinsai/’ with pattern ‘^index.php$’, result: -1
2022-07-23 16:30:27.447563 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] Rule: Match ‘produkto-zyma/pilki-dzinsai/’ with pattern ‘^en/wp-login.php’, result: -1
2022-07-23 16:30:27.447571 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] Rule: Match ‘produkto-zyma/pilki-dzinsai/’ with pattern ‘^lt/wp-login.php’, result: -1
2022-07-23 16:30:27.447579 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] Rule: Match ‘produkto-zyma/pilki-dzinsai/’ with pattern ‘.’, result: 1
2022-07-23 16:30:27.447610 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] stat( /home/abiti.lt/public_html/produkto-zyma ) failed
2022-07-23 16:30:27.447657 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] stat( /home/abiti.lt/public_html/produkto-zyma ) failed
2022-07-23 16:30:27.447666 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] Source URI: ‘produkto-zyma/pilki-dzinsai/’ => Result URI: ‘/index.php’
2022-07-23 16:30:27.447675 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] Last Rule, stop!
2022-07-23 16:30:27.447683 [INFO] [57585] [172.70.135.76:64448:HTTP2-1#abiti.lt] [REWRITE] apply cache-control: ‘no-autoflush’.
