Fix your Installation instructions
The setup instructions are garbage, and the onboarding page does not work. I went through a ton of gotchas and had to use Gemini chat to tailor the instructions and fix the errors in them. Start using my rewritten instructions. Thank God for Gemini chat.
I tried posting the link to the Google Doc here, and also tried copying its contents as well, but because I’m new, you won’t let me post links to anything, so you get nada. Fix that, then we’ll talk.
https:// docs dot google dot com/document/d/1Fr42u1spmP9Wo6Ssfp0DHCmJEaI7cWPIC5deVZnlWBs/edit?usp=sharing
for me was easy to install - just one click script install and everything works cyberpanel 2.4
NOPE. It populates the hostname with an unwanted hostname. If you use any sort of VPS, your machine has a reverse DNS set for you and that is what the installer uses to register the domain name and create SSL certificates. It does not let you use a proper self-selected domain name.
example:
machine0203 dot somerandomhost dot com
People who buy VPS machines do not want to operate their tools on the automatically-assigned subdomain on the host’s domain. They want to use their own domain name:
panel dot mypersonalsite dot dev
