hi
<FilesMatch “.(?i:pdf)$”>
ForceType application/octet-stream
Header set Content-Disposition attachment
…added to .htaccess but doesn’t work
please help
thanks you
Any major changes to htaccess files need Openlitespeed Restart. Go to Manage Services menu of cyberpanel and then restart Openlitespeed
I really missed to read the codes you mentioned.
Openlitespeed doesnt support this. Rewrite and rewritecond rules are only supported by Openlitespeed.
thanks for reply.
Is there a similar solution compatible with Lightspeed ?
Create a context for example…
And if that is possible…how do i translate this filematch code to context.
You can use this guide to set extra headers on OpenLiteSpeed while using CyberPanel → How to set custom/extra headers for OpenLiteSpeed while using CyberPanel - CyberHosting
problem solved
solution :
context exp:^.*(pdf)$ {
allowBrowse 1
extraHeaders <<<END_extraHeaders
END_extraHeaders
rewrite {
addDefaultCharset off
phpIniOverride {
thanks you.
