Hello, I am presenting a failure in my server. I have several websites that work perfectly and in which I can install the ssl without any problem. But now I present a problem in a specific domain, which lost its ssl certificate. When trying to install it gives me an error: neophonestore.com:Verify error:2a02:4780:1:789:0:1204:86d8:23: Invalid response from http://neophonestore.com/.well-known/acme-challenge/gd1WcAcwceqJ-TNwTbV6uyw3pfqPM1vhwEz80pB-3ho: 404
But if I access that url if I get the key.
I have tried uninstalling the security of my server, but nothing.
if you access the url you can see that it is showing the key correctly, so this could not be the problem, also check the dns and they seem to be working
I checked DNS checker to see if I had any problems with DNS and it seems to work. The truth is that I am not aware of this operation or if I need any DNS, but previously it worked
But according to this I was checking carefully and I found a wrong DNS (AAA) which caused the problem. Just delete it. I kept my Nameservers the same…
Thank you
