mjf777
1
I’m currently using Digital Ocean for my hosting. I’d like to extend the /home volume with block storage. I see I can probably do this via LVM (hardware - How to set up multiple hard drives as one volume? - Ask Ubuntu)
Any suggestions on this?
Also, is there any docs available for the Connect service (https://platform.cyberpanel.net)?
Thanks,
M
If you want to play with /home better do it before creating any website and rest should be fine.
To connect the server to platform just enter the admin username and its password, then most of the functions are similar to CyberPanel itself.
mjf777
3
Thank you.
Will there be an issue if I copy all contents of /home (including existing websites) to another volume and map that as the /home folder?
