MISHOoO #1
i face errors while upgrading the cyberpanel i’ll post screenshots of the erros
i need to know is this a problem or its ok ?
OS: ubuntu server 22
chmod: cannot access ‘/etc/pdns/pdns.conf’: No such file or directory
[11.03.2024_10-23-59] #########################################################################
[11.03.2024_10-23-59] chown core code failed, trying again, try number: 1
[11.03.2024_10-23-59] chown core code failed, trying again, try number: 2
[11.03.2024_10-23-59] chown core code failed, trying again, try number: 3
[11.03.2024_10-23-59] chown core code failed.
[11.03.2024_10-24-00] #########################################################################
sed: can’t read /usr/local/lsws/conf/httpd_config.xml: No such file or directory
[11.03.2024_10-24-00] Start LSCPD successful.
Failed to stop cpssh.service: Unit cpssh.service not loaded.
[11.03.2024_10-24-00] fix csf if there failed, trying again, try number: 1
[11.03.2024_10-24-00] fix csf if there failed, trying again, try number: 2
[11.03.2024_10-24-00] fix csf if there failed, trying again, try number: 3
[11.03.2024_10-24-00] fix csf if there failed.
[Sun Nov 3 10:24:00 AM UTC 2024] Already up to date!
[Sun Nov 3 10:24:00 AM UTC 2024] Upgrade successful!
and in the end it says upgraded successfully, but what about the above errors?
