I have this error each time (each 30minutes) after cron for “sessionclean”.
I tried upgrade cyberpanel - no success. Even on new machine the same error.
I have 5 different machines with cyberpanel and on each of them this error in logs.
Mar 1 00:09:01 localhost CRON[8166]: (root) CMD ( [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Mar 1 00:09:12 localhost systemd[1]: Starting Clean php session files…
Mar 1 00:09:12 localhost sessionclean[8192]: PHP Warning: PHP Startup: Unable to load dynamic library ‘pdo.so’ (tried: /usr/local/lsws/lsphp73/lib/php/20180731/pdo.so (/usr/local/lsws/lsphp73/lib/php/20180731/pdo.so: cannot open shared object file: No such file or directory), /usr/local/lsws/lsphp73/lib/php/20180731/pdo.so.so (/usr/local/lsws/lsphp73/lib/php/20180731/pdo.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Mar 1 00:09:12 localhost sessionclean[8192]: PHP Warning: PHP Startup: Unable to load dynamic library ‘xml.so’ (tried: /usr/local/lsws/lsphp73/lib/php/20180731/xml.so (/usr/local/lsws/lsphp73/lib/php/20180731/xml.so: cannot open shared object file: No such file or directory), /usr/local/lsws/lsphp73/lib/php/20180731/xml.so.so (/usr/local/lsws/lsphp73/lib/php/20180731/xml.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Mar 1 00:09:12 localhost sessionclean[8192]: PHP Warning: PHP Startup: Unable to load dynamic library ‘calendar.so’ (tried: /usr/local/lsws/lsphp73/lib/php/20180731/calendar.so (/usr/local/lsws/lsphp73/lib/php/20180731/calendar.so: cannot open shared object file: No such file or directory), /usr/local/lsws/lsphp73/lib/php/20180731/calendar.so.so (/usr/local/lsws/lsphp73/lib/php/20180731/calendar.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Mar 1 00:09:12 localhost sessionclean[8192]: PHP Warning: PHP Startup: Unable to load dynamic library ‘ctype.so’ (tried: /usr/local/lsws/lsphp73/lib/php/20180731/ctype.so (/usr/local/lsws/lsphp73/lib/php/20180731/ctype.so: cannot open shared object file: No such file or directory), /usr/local/lsws/lsphp73/lib/php/20180731/ctype.so.so (/usr/local/lsws/lsphp73/lib/php/20180731/ctype.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Mar 1 00:09:12 localhost sessionclean[8192]: PHP Warning: PHP Startup: Unable to load dynamic library ‘dom.so’ (tried: /usr/local/lsws/lsphp73/lib/php/20180731/dom.so (/usr/local/lsws/lsphp73/lib/php/20180731/dom.so: cannot open shared object file: No such file or directory), /usr/local/lsws/lsphp73/lib/php/20180731/dom.so.so (/usr/local/lsws/lsphp73/lib/php/20180731/dom.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Mar 1 00:09:12 localhost sessionclean[8192]: PHP Warning: PHP Startup: Unable to load dynamic library ‘exif.so’ (tried: /usr/local/lsws/lsphp73/lib/php/20180731/exif.so (/usr/local/lsws/lsphp73/lib/php/20180731/exif.so: cannot open shared object file: No such file or directory), /usr/local/lsws/lsphp73/lib/php/20180731/exif.so.so (/usr/local/lsws/lsphp73/lib/php/20180731/exif.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Mar 1 00:09:12 localhost sessionclean[8192]: PHP Warning: PHP Startup: Unable to load dynamic library ‘ffi.so’ (tried: /usr/local/lsws/lsphp73/lib/php/20180731/ffi.so (/usr/local/lsws/lsphp73/lib/php/20180731/ffi.so: cannot open shared object file: No such file or directory), /usr/local/lsws/lsphp73/lib/php/20180731/ffi.so.so (/usr/local/lsws/lsphp73/lib/php/20180731/ffi.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Mar 1 00:09:12 localhost sessionclean[8192]: PHP Warning: PHP Startup: Unable to load dynamic library ‘fileinfo.so’ (tried: /usr/local/lsws/lsphp73/lib/php/20180731/fileinfo.so (/usr/local/lsws/lsphp73/lib/php/20180731/fileinfo.so: cannot open shared object file: No such file or directory), /usr/local/lsws/lsphp73/lib/php/20180731/fileinfo.so.so (/usr/local/lsws/lsphp73/lib/php/20180731/fileinfo.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Mar 1 00:09:12 localhost sessionclean[8192]: PHP Warning: PHP Startup: Unable to load dynamic library ‘ftp.so’ (tried: /usr/local/lsws/lsphp73/lib/php/20180731/ftp.so (/usr/local/lsws/lsphp73/lib/php/20180731/ftp.so: cannot open shared object file: No such file or directory), /usr/local/lsws/lsphp73/lib/php/20180731/ftp.so.so (/usr/local/lsws/lsphp73/lib/php/20180731/ftp.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Mar 1 00:09:12 localhost sessionclean[8192]: PHP Warning: PHP Startup: Unable to load dynamic library ‘gettext.so’ (tried: /usr/local/lsws/lsphp73/lib/php/20180731/gettext.so (/usr/local/lsws/lsphp73/lib/php/20180731/gettext.so: cannot open shared object file: No such file or directory), /usr/local/lsws/lsphp73/lib/php/20180731/gettext.so.so (/usr/local/lsws/lsphp73/lib/php/20180731/gettext.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Mar 1 00:09:12 localhost sessionclean[8192]: PHP Warning: PHP Startup: Unable to load dynamic library ‘iconv.so’ (tried: /usr/local/lsws/lsphp73/lib/php/20180731/iconv.so (/usr/local/lsws/lsphp73/lib/php/20180731/iconv.so: cannot open shared object file: No such file or directory), /usr/local/lsws/lsphp73/lib/php/20180731/iconv.so.so (/usr/local/lsws/lsphp73/lib/php/20180731/iconv.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Mar 1 00:09:12 localhost sessionclean[8192]: PHP Warning: PHP Startup: Unable to load dynamic library ‘phar.so’ (tried: /usr/local/lsws/lsphp73/lib/php/20180731/phar.so (/usr/local/lsws/lsphp73/lib/php/20180731/phar.so: cannot open shared object file: No such file or directory), /usr/local/lsws/lsphp73/lib/php/20180731/phar.so.so (/usr/local/lsws/lsphp73/lib/php/20180731/phar.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Mar 1 00:09:12 localhost sessionclean[8192]: PHP Warning: PHP Startup: Unable to load dynamic library ‘posix.so’ (tried: /usr/local/lsws/lsphp73/lib/php/20180731/posix.so (/usr/local/lsws/lsphp73/lib/php/20180731/posix.so: cannot open shared object file: No such file or directory), /usr/local/lsws/lsphp73/lib/php/20180731/posix.so.so (/usr/local/lsws/lsphp73/lib/php/20180731/posix.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Mar 1 00:09:12 localhost sessionclean[8192]: PHP Warning: PHP Startup: Unable to load dynamic library ‘readline.so’ (tried: /usr/local/lsws/lsphp73/lib/php/20180731/readline.so (/usr/local/lsws/lsphp73/lib/php/20180731/readline.so: cannot open shared object file: No such file or directory), /usr/local/lsws/lsphp73/lib/php/20180731/readline.so.so (/usr/local/lsws/lsphp73/lib/php/20180731/readline.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Mar 1 00:09:12 localhost sessionclean[8192]: PHP Warning: PHP Startup: Unable to load dynamic library ‘shmop.so’ (tried: /usr/local/lsws/lsphp73/lib/php/20180731/shmop.so (/usr/local/lsws/lsphp73/lib/php/20180731/shmop.so: cannot open shared object file: No such file or directory), /usr/local/lsws/lsphp73/lib/php/20180731/shmop.so.so (/usr/local/lsws/lsphp73/lib/php/20180731/shmop.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Mar 1 00:09:12 localhost sessionclean[8192]: PHP Warning: PHP Startup: Unable to load dynamic library ‘simplexml.so’ (tried: /usr/local/lsws/lsphp73/lib/php/20180731/simplexml.so (/usr/local/lsws/lsphp73/lib/php/20180731/simplexml.so: cannot open shared object file: No such file or directory), /usr/local/lsws/lsphp73/lib/php/20180731/simplexml.so.so (/usr/local/lsws/lsphp73/lib/php/20180731/simplexml.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Mar 1 00:09:12 localhost sessionclean[8192]: PHP Warning: PHP Startup: Unable to load dynamic library ‘sockets.so’ (tried: /usr/local/lsws/lsphp73/lib/php/20180731/sockets.so (/usr/local/lsws/lsphp73/lib/php/20180731/sockets.so: cannot open shared object file: No such file or directory), /usr/local/lsws/lsphp73/lib/php/20180731/sockets.so.so (/usr/local/lsws/lsphp73/lib/php/20180731/sockets.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Mar 1 00:09:12 localhost sessionclean[8192]: PHP Warning: PHP Startup: Unable to load dynamic library ‘sysvmsg.so’ (tried: /usr/local/lsws/lsphp73/lib/php/20180731/sysvmsg.so (/usr/local/lsws/lsphp73/lib/php/20180731/sysvmsg.so: cannot open shared object file: No such file or directory), /usr/local/lsws/lsphp73/lib/php/20180731/sysvmsg.so.so (/usr/local/lsws/lsphp73/lib/php/20180731/sysvmsg.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Mar 1 00:09:12 localhost sessionclean[8192]: PHP Warning: PHP Startup: Unable to load dynamic library ‘sysvsem.so’ (tried: /usr/local/lsws/lsphp73/lib/php/20180731/sysvsem.so (/usr/local/lsws/lsphp73/lib/php/20180731/sysvsem.so: cannot open shared object file: No such file or directory), /usr/local/lsws/lsphp73/lib/php/20180731/sysvsem.so.so (/usr/local/lsws/lsphp73/lib/php/20180731/sysvsem.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Mar 1 00:09:12 localhost sessionclean[8192]: PHP Warning: PHP Startup: Unable to load dynamic library ‘sysvshm.so’ (tried: /usr/local/lsws/lsphp73/lib/php/20180731/sysvshm.so (/usr/local/lsws/lsphp73/lib/php/20180731/sysvshm.so: cannot open shared object file: No such file or directory), /usr/local/lsws/lsphp73/lib/php/20180731/sysvshm.so.so (/usr/local/lsws/lsphp73/lib/php/20180731/sysvshm.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Mar 1 00:09:12 localhost sessionclean[8192]: PHP Warning: PHP Startup: Unable to load dynamic library ‘tokenizer.so’ (tried: /usr/local/lsws/lsphp73/lib/php/20180731/tokenizer.so (/usr/local/lsws/lsphp73/lib/php/20180731/tokenizer.so: cannot open shared object file: No such file or directory), /usr/local/lsws/lsphp73/lib/php/20180731/tokenizer.so.so (/usr/local/lsws/lsphp73/lib/php/20180731/tokenizer.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Mar 1 00:09:12 localhost sessionclean[8192]: PHP Warning: PHP Startup: Unable to load dynamic library ‘xmlreader.so’ (tried: /usr/local/lsws/lsphp73/lib/php/20180731/xmlreader.so (/usr/local/lsws/lsphp73/lib/php/20180731/xmlreader.so: cannot open shared object file: No such file or directory), /usr/local/lsws/lsphp73/lib/php/20180731/xmlreader.so.so (/usr/local/lsws/lsphp73/lib/php/20180731/xmlreader.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Mar 1 00:09:12 localhost sessionclean[8192]: PHP Warning: PHP Startup: Unable to load dynamic library ‘xmlwriter.so’ (tried: /usr/local/lsws/lsphp73/lib/php/20180731/xmlwriter.so (/usr/local/lsws/lsphp73/lib/php/20180731/xmlwriter.so: cannot open shared object file: No such file or directory), /usr/local/lsws/lsphp73/lib/php/20180731/xmlwriter.so.so (/usr/local/lsws/lsphp73/lib/php/20180731/xmlwriter.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Mar 1 00:09:12 localhost sessionclean[8192]: PHP Warning: PHP Startup: Unable to load dynamic library ‘xsl.so’ (tried: /usr/local/lsws/lsphp73/lib/php/20180731/xsl.so (/usr/local/lsws/lsphp73/lib/php/20180731/xsl.so: cannot open shared object file: No such file or directory), /usr/local/lsws/lsphp73/lib/php/20180731/xsl.so.so (/usr/local/lsws/lsphp73/lib/php/20180731/xsl.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Mar 1 00:09:12 localhost systemd[1]: phpsessionclean.service: Succeeded.
Mar 1 00:09:12 localhost systemd[1]: Finished Clean php session files.
