Good day!
I can’t update the control panel, there’s an error at the end:
command: /usr/local/CyberPanel/bin/python3 -u -c ‘import sys, setuptools, tok enize; sys.argv[0] = ‘"’"’/tmp/pip-install-z_vy94rd/mysqlclient/setup.py’"’"’; _ file_=’"’"’/tmp/pip-install-z_vy94rd/mysqlclient/setup.py’"’"’;f=getattr(token ize, ‘"’"‘open’"’"’, open)(file);code=f.read().replace(’"’"’\r
‘"’"’);f.close();exec(compile(code, file, ‘"’"‘exec’"’"’))’ bdist_wheel -d /tmp/pip-wheel-xki3499h
cwd: /tmp/pip-install-z_vy94rd/mysqlclient/
Complete output (30 lines):
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-x86_64-3.6
creating build/lib.linux-x86_64-3.6/MySQLdb
copying MySQLdb/init.py → build/lib.linux-x86_64-3.6/MySQLdb
copying MySQLdb/exceptions.py → build/lib.linux-x86_64-3.6/MySQLdb
copying MySQLdb/compat.py → build/lib.linux-x86_64-3.6/MySQLdb
copying MySQLdb/connections.py → build/lib.linux-x86_64-3.6/MySQLdb
copying MySQLdb/converters.py → build/lib.linux-x86_64-3.6/MySQLdb
copying MySQLdb/cursors.py → build/lib.linux-x86_64-3.6/MySQLdb
copying MySQLdb/release.py → build/lib.linux-x86_64-3.6/MySQLdb
copying MySQLdb/times.py → build/lib.linux-x86_64-3.6/MySQLdb
creating build/lib.linux-x86_64-3.6/MySQLdb/constants
copying MySQLdb/constants/init.py → build/lib.linux-x86_64-3.6/MySQLdb/co nstants
copying MySQLdb/constants/CLIENT.py → build/lib.linux-x86_64-3.6/MySQLdb/cons tants
copying MySQLdb/constants/CR.py → build/lib.linux-x86_64-3.6/MySQLdb/constant s
copying MySQLdb/constants/ER.py → build/lib.linux-x86_64-3.6/MySQLdb/constant s
copying MySQLdb/constants/FIELD_TYPE.py → build/lib.linux-x86_64-3.6/MySQLdb/ constants
copying MySQLdb/constants/FLAG.py → build/lib.linux-x86_64-3.6/MySQLdb/consta nts
running build_ext
building 'MySQLdb.mysql’ extension
creating build/temp.linux-x86_64-3.6
creating build/temp.linux-x86_64-3.6/MySQLdb
gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -O2 -g -pipe -Wall -Wp ,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-si ze=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -fPIC -Dversion_info=(1,4,6,‘final’,0) -D__version=1.4.6 -I/usr/include/mysql -I/us r/include/mysql/mysql -I/usr/include/python3.6m -c MySQLdb/_mysql.c -o build/tem p.linux-x86_64-3.6/MySQLdb/_mysql.o
gcc -pthread -shared -Wl,-z,relro -g build/temp.linux-x86_64-3.6/MySQLdb/_mysq l.o -L/usr/lib64/ -L/usr/lib64 -lmariadb -lpython3.6m -o build/lib.linux-x86_64- 3.6/MySQLdb/_mysql.cpython-36m-x86_64-linux-gnu.so
/usr/bin/ld: cannot find -lmariadb
collect2: error: ld returned 1 exit status
error: command ‘gcc’ failed with exit status 1
ERROR: Failed building wheel for mysqlclient
Running setup.py clean for mysqlclient
Building wheel for parsedatetime (setup.py) … done
Created wheel for parsedatetime: filename=parsedatetime-2.4-py3-none-any.whl s ize=42748 sha256=993f93f6dac8ddb50a6e0a6074d57acf70f477c0df9e0a99a4d8b26bdfea954 2
Stored in directory: /tmp/pip-ephem-wheel-cache-cbhclu8r/wheels/b8/09/4d/98683 3f1c3d5c763ae571da9f0aa1eeb47059443a6c97340f6
Building wheel for prettytable (setup.py) … done
Created wheel for prettytable: filename=prettytable-0.7.2-py3-none-any.whl siz e=13698 sha256=040c99b749509a6a633b003a8a2fa791aa200598d04508e0f3123a3ae9c48dab
Stored in directory: /tmp/pip-ephem-wheel-cache-cbhclu8r/wheels/90/15/c3/5f28b 42ae9c81638570b8b7ed654e0f98c5fdc08875869511b
Building wheel for psutil (setup.py) … done
Created wheel for psutil: filename=psutil-5.4.3-cp36-cp36m-linux_x86_64.whl si ze=246626 sha256=6dcf94967a1f69ef70d83071103e5589e52d05d79d4db4e1c01dae86a8e0cff b
Stored in directory: /tmp/pip-ephem-wheel-cache-cbhclu8r/wheels/e7/eb/6f/2490c dd6839c71022abe1d7ab1c98945f486729eee003d866f
Building wheel for py3dns (setup.py) … done
Created wheel for py3dns: filename=py3dns-3.2.1-py3-none-any.whl size=20839 sh a256=4d4705776b6f09265a271ad1e3368fb88a5ba0d6b502bffe546558bf4b4f9053
Stored in directory: /tmp/pip-ephem-wheel-cache-cbhclu8r/wheels/c5/26/01/4fd5b 819fbb95b4975368ee10c4e38dce08f0663aab86c7998
Building wheel for pycparser (setup.py) … done
Created wheel for pycparser: filename=pycparser-2.18-py2.py3-none-any.whl size =206687 sha256=04a644958caeab1e4a56d09ed2f5e5a5f08ff15cdece6809ff6a0faf5569da5d
Stored in directory: /tmp/pip-ephem-wheel-cache-cbhclu8r/wheels/be/ba/89/4df1a 952bcd0716ac1d5f6f051233e1f3a653948f08bc0a7be
Building wheel for pygpgme (setup.py) … done
Created wheel for pygpgme: filename=pygpgme-0.3-cp36-cp36m-linux_x86_64.whl si ze=89927 sha256=c8f863ecb4af05076674eb6e9f19ec05dea618a9f05907ec5770e1ac73df3c41
Stored in directory: /tmp/pip-ephem-wheel-cache-cbhclu8r/wheels/d9/4b/a3/db0e1 513c11eb7c0dfff111a9145be354820cbf2d9ec08bcb3
Building wheel for pyudev (setup.py) … done
Created wheel for pyudev: filename=pyudev-0.15-py3-none-any.whl size=45045 sha 256=1005612242373feb7d04ab8701e84bb3ae8aa73ca10455cd5ecca6a692fda3f1
Stored in directory: /tmp/pip-ephem-wheel-cache-cbhclu8r/wheels/01/f9/86/ad0e6 3c5c58123027c1bf25b45f3f4def9b10cd9fe8051ae5d
Building wheel for pyxattr (setup.py) … done
Created wheel for pyxattr: filename=pyxattr-0.7.1-cp36-cp36m-linux_x86_64.whl size=37368 sha256=98b03a78901fdfa5b29f864564a2231342e9777a4b4afe397947b2331e4b09 51
Stored in directory: /tmp/pip-ephem-wheel-cache-cbhclu8r/wheels/07/90/42/5afe8 d2103817ce5eb87af6348e428d7e3f97791208538419d
Building wheel for PyYAML (setup.py) … done
Created wheel for PyYAML: filename=PyYAML-3.10-cp36-cp36m-linux_x86_64.whl siz e=42953 sha256=73199662ff6c15665f79b0bb86331f19dea6244b604630a612c64b38071e22ba
Stored in directory: /tmp/pip-ephem-wheel-cache-cbhclu8r/wheels/84/e3/f6/21fe8 0c1fc3ba6164eac04c61707a7a6d312290cfa58f94e06
Building wheel for SimpleWebSocketServer (setup.py) … done
Created wheel for SimpleWebSocketServer: filename=SimpleWebSocketServer-0.1.1- py3-none-any.whl size=9494 sha256=d66a839b6ea46e190c7574d6cabb1783a015768cad779c c617bbc57a2d592d49
Stored in directory: /tmp/pip-ephem-wheel-cache-cbhclu8r/wheels/ec/39/bc/12698 48243eda619fa735fea3a00a9c902c587d3ee56d0b8fb
Successfully built Babel backports.ssl-match-hostname ConfigArgParse configobj d ecorator future ipaddress IPy Jinja2 jsonpatch jsonpointer MarkupSafe parsedatet ime prettytable psutil py3dns pycparser pygpgme pyudev pyxattr PyYAML SimpleWebS ocketServer
Failed to build mysqlclient
Installing collected packages: pytz, pyRFC3339, setuptools, six, pycparser, cffi , cryptography, pyOpenSSL, pbr, mock, josepy, idna, urllib3, chardet, certifi, r equests, acme, asgiref, asn1crypto, Babel, backports.ssl-match-hostname, bcrypt, python-dateutil, docutils, jmespath, botocore, s3transfer, boto3, future, parse datetime, zope.event, zope.interface, zope.component, ConfigArgParse, configobj, certbot, decorator, sqlparse, Django, websocket-client, docker-pycreds, docker, enum34, funcsigs, ipaddress, IPy, MarkupSafe, Jinja2, jsonpointer, jsonpatch, m ysqlclient, PyNaCl, paramiko, ptyprocess, pexpect, prettytable, psutil, py3dns, pygpgme, pyudev, pyxattr, PyYAML, requests-file, SimpleWebSocketServer, tldextra ct
Running setup.py install for mysqlclient … error
command: /usr/local/CyberPanel/bin/python3 -u -c ‘import sys, setuptools, t okenize; sys.argv[0] = ‘"’"’/tmp/pip-install-z_vy94rd/mysqlclient/setup.py’"’"’; file=’"’"’/tmp/pip-install-z_vy94rd/mysqlclient/setup.py’"’"’;f=getattr(tok enize, ‘"’"‘open’"’"’, open)(file);code=f.read().replace(’"’"’\r
'”’"’);f.close();exec(compile(code, file, ‘"’"‘exec’"’"’))’ install --re cord /tmp/pip-record-j0aml2xl/install-record.txt --single-version-externally-man aged --compile --install-headers /usr/local/CyberPanel/include/site/python3.6/my sqlclient
running install
running build
running build_py
creating build
copying MySQLdb/constants/init.py → build/lib.linux-x86_64-3.6/MySQLdb/ constants
copying MySQLdb/constants/CLIENT.py → build/lib.linux-x86_64-3.6/MySQLdb/co nstants
copying MySQLdb/constants/CR.py → build/lib.linux-x86_64-3.6/MySQLdb/consta nts
copying MySQLdb/constants/ER.py → build/lib.linux-x86_64-3.6/MySQLdb/consta nts
copying MySQLdb/constants/FIELD_TYPE.py → build/lib.linux-x86_64-3.6/MySQLd b/constants
copying MySQLdb/constants/FLAG.py → build/lib.linux-x86_64-3.6/MySQLdb/cons tants
running build_ext
gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -O2 -g -pipe -Wall - Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer- size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -fP IC -Dversion_info=(1,4,6,‘final’,0) -D__version=1.4.6 -I/usr/include/mysql -I/ usr/include/mysql/mysql -I/usr/include/python3.6m -c MySQLdb/_mysql.c -o build/t emp.linux-x86_64-3.6/MySQLdb/_mysql.o
gcc -pthread -shared -Wl,-z,relro -g build/temp.linux-x86_64-3.6/MySQLdb/_my sql.o -L/usr/lib64/ -L/usr/lib64 -lmariadb -lpython3.6m -o build/lib.linux-x86_6 4-3.6/MySQLdb/mysql.cpython-36m-x86_64-linux-gnu.so
ERROR: Command errored out with exit status 1: /usr/local/CyberPanel/bin/python3 -u -c ‘import sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-z vy94rd/mysqlclient/setup.py’"’"’; file=’"’"’/tmp/pip-install-z_vy94rd/mysqlc lient/setup.py’"’"’;f=getattr(tokenize, ‘"’"‘open’"’"’, open)(file);code=f.r ead().replace(’"’"’\r
‘"’"’);f.close();exec(compile(code, _file _, ‘"’"‘exec’"’"’))’ install --record /tmp/pip-record-j0aml2xl/install-record.tx t --single-version-externally-managed --compile --install-headers /usr/local/Cyb erPanel/include/site/python3.6/mysqlclient Check the logs for full command outpu t.
command failed, exiting…
