Error restore website [5009]
I did this:
And then:
sh: 0: Can’t open /dev/fd/63
info@cyberpanel-2-vm:/home$ % Total % Received % Xferd Average Speed Time Time Time Current
100 396 100 396 0 0 2212 0 --:–:-- --:–:-- --:–:-- 2212
(23) Failed writing body
Just to give more info, it’s a right now installed vm from Google Cloud, the Official Cyberpanel.
Do not install cyberpanel using the provided image in google cloud. Use SSH method to install cyberpanel from scratch.
Hello @die2mrw007,
While restoring a backup on the latest cyberpanel, it throws [736][5009].
Error-log:
(1064, “You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'SET PASSWORD FOR ‘U4Hgdy0M07UhaG’@‘localhost’ = ‘*A41A8B7C84C13D94BFD54AF0527…’ at line 1”)[restoreDatabaseBackup]
I haven’t changed mySQL password and I already have checked the same at both places:
  1. /etc/cyberpanel/mysqlPassword
  2. /usr/local/CyberCP/CyberCP/settings.py
Now, what is the possible solution?
The password() function may have changed in latest mariadb version and hence such error
Do u remember what was the cyberpanel version or mariadb version when you created this backup?
As cyberpanel version does not change automatically, the previous version was as same as current one.
So, how is the backup file structure? Does it has sql file in it?
If so, you can open it in SQL editor and then change/reset the password using ALTER command for user ‘U4Hgdy0M07UhaG’
and then later try to restore your backup which should successfully execute.
When I try to retrieve a backup I get this error: Compressed file ended before the end-of-stream marker was reached [736][5009].
I have not changed the mysql password.
In the logs I only get this:
[06.16.2024_12-33-39] /home/almamarket.com/backup/
[06.16.2024_12-33-39] /home/almamarket.com/backup/backup-almamarket.com-06.16.2024_12-33-39
[06.16.2024_14-03-56] Compressed file ended before the end-of-stream marker was reached [startRestore] [06.16.2024_14-03-59] /home/almamarket.com/backup/backup-almamarket.com
[06.16.2024_14-11-53] Compressed file ended before the end-of-stream marker was reached [startRestore].
Any solution?
Thank you,
Hello did you have solution for this ? I’m facing the same error: error: Compressed file ended before the end-of-stream marker was reached [736][5009]
I’ve already changed the mysql password, but it still error when restoring onto the new server.
This is the logs:
[06.25.2025_05-55-59] sudo cat /home/backup/transfer-7710/backup_log
[06.25.2025_05-56-01] Compressed file ended before the end-of-stream marker was reached [startRestore]
[06.25.2025_05-56-01] Path vs the final url : /backup/localRestoreStatus
Please help
