When I try to access the CyberPanel interface, I receive the following error:
Internal Error
The server encountered an unexpected condition which prevented it from fulfilling the request
My server info:
[root@wp lscp]# cat /etc/redhat-release
AlmaLinux release 9.5 (Teal Serval)
[root@wp ~]# cat /usr/local/CyberCP/version.txt
{"version": "2.4", "build": "0"}
[root@wp ~]# free -m
total used free shared buff/cache available
Mem: 3658 805 1761 115 1425 2852
Swap: 2047 0 2047
[root@wp ~]# df -h
Filesystem Size Used Avail Use% Mounted on
devtmpfs 4.0M 0 4.0M 0% /dev
tmpfs 1.8G 106M 1.7G 6% /dev/shm
tmpfs 732M 8.5M 724M 2% /run
/dev/vda1 99G 48G 46G 52% /
tmpfs 366M 4.0K 366M 1% /run/user/0
Trying to update:
[root@wp lscp]# cyberpanel upgrade
[05.22.2025_17-55-19] /usr/bin/cyberpanel_utility --upgrade
[root@wp lscp]# /usr/bin/cyberpanel_utility --upgrade
/usr/bin/cyberpanel_utility: line 4: warning: setlocale: LC_CTYPE: cannot change locale (en_US.UTF-8): No such file or directory
Checking root privileges...
You are running as root...
Checking Cyberpanel Utility update...
CyberPanel Utility Script is up to date...
Unable to detect your system...
CyberPanel is supported on x86_64 based Ubuntu 18.04, Ubuntu 20.04, Ubuntu 20.10, Ubuntu 22.04, CentOS 7, CentOS 8, AlmaLinux 8, RockyLinux 8, CloudLinux 7, CloudLinux 8, openEuler 20.03, openEuler 22.03...
Services status:
[root@wp bin]# service lscpd status
Redirecting to /bin/systemctl status lscpd.service
● lscpd.service - LSCPD Daemon
Loaded: loaded (/etc/systemd/system/lscpd.service; enabled; preset: disabled)
Active: active (running) since Thu 2025-05-22 22:42:21 IST; 53min ago
Process: 624 ExecStart=/usr/local/lscp/bin/lscpdctrl start (code=exited, status=0/SUCCESS)
Main PID: 695 (lscpd)
CGroup: /system.slice/lscpd.service
├─ 695 "lscpd (lscpd - main)"
├─ 696 "lscpd (lscgid)"
├─ 698 "lscpd (lscpd - #01)"
├─ 699 /usr/local/CyberCP/bin/lswsgi -m /usr/local/CyberCP/CyberCP/wsgi.py
└─3383 /usr/local/CyberCP/bin/lswsgi -m /usr/local/CyberCP/CyberCP/wsgi.py
May 22 22:42:19 wp.portaleducadora.com systemd[1]: Starting LSCPD Daemon...
May 22 22:42:19 wp.portaleducadora.com lscpdctrl[624]: [OK] lscpd: pid=695.
May 22 22:42:21 wp.portaleducadora.com systemd[1]: Started LSCPD Daemon.
[root@wp bin]# service lsws status
Redirecting to /bin/systemctl status lsws.service
● lshttpd.service - OpenLiteSpeed HTTP Server
Loaded: loaded (/usr/lib/systemd/system/lshttpd.service; enabled; preset: disabled)
Process: 783 ExecStart=/usr/local/lsws/bin/lswsctrl start (code=exited, status=0/SUCCESS)
Main PID: 846 (litespeed)
CGroup: /system.slice/lshttpd.service
├─846 "openlitespeed (lshttpd - main)"
├─849 "openlitespeed (lscgid)"
├─873 "openlitespeed (lshttpd - #01)"
├─874 "openlitespeed (lshttpd - #02)"
├─875 "openlitespeed (lshttpd - #03)"
└─876 "openlitespeed (lshttpd - #04)"
May 22 22:42:19 wp.portaleducadora.com systemd[1]: Starting OpenLiteSpeed HTTP Server...
May 22 22:42:19 wp.portaleducadora.com lswsctrl[783]: [OK] litespeed: pid=846.
May 22 22:42:21 wp.portaleducadora.com systemd[1]: Started OpenLiteSpeed HTTP Server.
[root@wp bin]# systemctl status mariadb
● mariadb.service - MariaDB 10.11.11 database server
Loaded: loaded (/usr/lib/systemd/system/mariadb.service; enabled; preset: disabled)
Drop-In: /etc/systemd/system/mariadb.service.d
└─migrated-from-my.cnf-settings.conf
Active: active (running) since Thu 2025-05-22 22:42:19 IST; 58min ago
Docs: man:mariadbd(8)
https://mariadb.com/kb/en/library/systemd/
Process: 636 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=ex>
Process: 678 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= || VAR=`/usr/b>
Process: 766 ExecStartPost=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=e>
Main PID: 693 (mariadbd)
Status: "Taking your SQL requests now..."
Tasks: 8 (limit: 28678)
Memory: 229.7M
CPU: 385ms
CGroup: /system.slice/mariadb.service
└─693 /usr/sbin/mariadbd
May 22 22:42:19 wp.portaleducadora.com mariadbd[693]: 2025-05-22 22:42:19 0 [Note] InnoDB: File './>
May 22 22:42:19 wp.portaleducadora.com mariadbd[693]: 2025-05-22 22:42:19 0 [Note] InnoDB: log sequ>
May 22 22:42:19 wp.portaleducadora.com mariadbd[693]: 2025-05-22 22:42:19 0 [Note] InnoDB: Loading >
May 22 22:42:19 wp.portaleducadora.com mariadbd[693]: 2025-05-22 22:42:19 0 [Note] Plugin 'FEEDBACK>
May 22 22:42:19 wp.portaleducadora.com mariadbd[693]: 2025-05-22 22:42:19 0 [Note] Server socket cr>
May 22 22:42:19 wp.portaleducadora.com mariadbd[693]: 2025-05-22 22:42:19 0 [Note] InnoDB: Buffer p>
May 22 22:42:19 wp.portaleducadora.com mariadbd[693]: 2025-05-22 22:42:19 0 [Note] /usr/sbin/mariad>
May 22 22:42:19 wp.portaleducadora.com mariadbd[693]: Version: '10.11.11-MariaDB' socket: '/var/li>
May 22 22:42:19 wp.portaleducadora.com systemd[1]: Started MariaDB 10.11.11 database server.
cat /usr/local/lscp/logs/error.log
[root@wp bin]# cat /usr/local/lscp/logs/error.log
2025-05-22 22:42:19.274275 [NOTICE] Loading LiteSpeed/0.3.1 Open (TOBEREPLACEDWITHCURRENTDATE) ...
2025-05-22 22:42:19.274292 [NOTICE] Using [BoringSSL]
2025-05-22 22:42:19.275950 [NOTICE] [PID: 695]: forked cgid: 696
2025-05-22 22:42:19.277696 [NOTICE] [LscpdCommSocket] server socket: uds://usr/local/lscpd/admin/comm.sock and fd 11 uid 1000 gid 1000
2025-05-22 22:42:19.277899 [NOTICE] [AutoRestarter] new child process with pid=698 is forked!
2025-05-22 22:42:19.278293 [NOTICE] [child: 698] Successfully change current user to lscpd
2025-05-22 22:42:19.278316 [NOTICE] Child: 698] Core dump is disabled.
2025-05-22 22:42:19.278694 [INFO] [wsgi:cyberpanel:/] add child process pid: 699.
2025-05-22 22:42:19.278743 [NOTICE] [Child: 698] Setup swapping space...
2025-05-22 22:42:19.279077 [NOTICE] [Child: 698] LiteSpeed/0.3.1 Open starts successfully!
2025-05-22 22:42:20.081029 [INFO] checkStatusFile() called with uid 2002 randoffset -1.
2025-05-22 22:42:20.081072 [INFO] checkStatusFile() return 1.
2025-05-22 22:43:20.100189 [INFO] checkStatusFile() called with uid 2002 randoffset -1.
2025-05-22 22:43:20.100271 [INFO] checkStatusFile() return 1.
2025-05-22 22:44:20.098876 [INFO] checkStatusFile() called with uid 2002 randoffset -1.
2025-05-22 22:44:20.098916 [INFO] checkStatusFile() return 1.
2025-05-22 22:45:20.020474 [INFO] checkStatusFile() called with uid 2002 randoffset -1.
2025-05-22 22:45:20.020513 [INFO] checkStatusFile() return 1.
2025-05-22 22:46:20.059313 [INFO] checkStatusFile() called with uid 2002 randoffset -1.
2025-05-22 22:46:20.059350 [INFO] checkStatusFile() return 1.
2025-05-22 22:47:20.099503 [INFO] checkStatusFile() called with uid 2002 randoffset -1.
2025-05-22 22:47:20.099540 [INFO] checkStatusFile() return 1.
tail -n 100 /usr/local/lsws/logs/error.log
[root@wp bin]# tail -n 100 /usr/local/lsws/logs/error.log
2025-05-22 22:42:19.948373 [INFO] [875] Close SO_REUSEPORT #4 fd: 25.
2025-05-22 22:42:19.948377 [NOTICE] [875] [*:80] Worker #3 activates SO_REUSEPORT #3 socket, fd: 24
2025-05-22 22:42:19.948392 [INFO] [875] Close SO_REUSEPORT #1 fd: 26.
2025-05-22 22:42:19.948398 [INFO] [875] Close SO_REUSEPORT #2 fd: 27.
2025-05-22 22:42:19.948401 [INFO] [875] Close SO_REUSEPORT #4 fd: 29.
2025-05-22 22:42:19.948404 [NOTICE] [875] [*:443] Worker #3 activates SO_REUSEPORT #3 socket, fd: 28
2025-05-22 22:42:19.948410 [INFO] [875] Close SO_REUSEPORT #1 fd: 30.
2025-05-22 22:42:19.948413 [INFO] [875] Close SO_REUSEPORT #2 fd: 31.
2025-05-22 22:42:19.948416 [INFO] [875] Close SO_REUSEPORT #4 fd: 33.
2025-05-22 22:42:19.948419 [NOTICE] [875] [UDP *:443] Worker #3 activates SO_REUSEPORT #3 socket, fd: 32
2025-05-22 22:42:19.948455 [INFO] [875] [UDP:0.0.0.0:443] initPacketsIn: allocated 100 packets
2025-05-22 22:42:19.948469 [INFO] [875] Close SO_REUSEPORT #1 fd: 34.
2025-05-22 22:42:19.948474 [INFO] [875] Close SO_REUSEPORT #2 fd: 35.
2025-05-22 22:42:19.948477 [INFO] [875] Close SO_REUSEPORT #4 fd: 37.
2025-05-22 22:42:19.948480 [NOTICE] [875] [[::]:443] Worker #3 activates SO_REUSEPORT #3 socket, fd: 36
2025-05-22 22:42:19.948478 [NOTICE] [873] Successfully change current user to nobody
2025-05-22 22:42:19.948486 [INFO] [875] Close SO_REUSEPORT #1 fd: 38.
2025-05-22 22:42:19.948491 [INFO] [875] Close SO_REUSEPORT #2 fd: 39.
2025-05-22 22:42:19.948494 [INFO] [875] Close SO_REUSEPORT #4 fd: 41.
2025-05-22 22:42:19.948498 [NOTICE] [875] [UDP [::]:443] Worker #3 activates SO_REUSEPORT #3 socket, fd: 40
2025-05-22 22:42:19.948497 [NOTICE] [873] Core dump is enabled.
2025-05-22 22:42:19.948515 [INFO] [875] [UDP:[::]:443] initPacketsIn: allocated 100 packets
2025-05-22 22:42:19.948524 [NOTICE] [875] Stop listener *:7080, fd 20.
2025-05-22 22:42:19.948679 [NOTICE] [875] Successfully change current user to nobody
2025-05-22 22:42:19.948692 [NOTICE] [875] Core dump is enabled.
2025-05-22 22:42:19.948707 [NOTICE] [875] Setup swapping space...
2025-05-22 22:42:19.948913 [INFO] [874] Close SO_REUSEPORT #1 fd: 22.
2025-05-22 22:42:19.948948 [INFO] [874] Close SO_REUSEPORT #3 fd: 24.
2025-05-22 22:42:19.948953 [INFO] [874] Close SO_REUSEPORT #4 fd: 25.
2025-05-22 22:42:19.948957 [NOTICE] [874] [*:80] Worker #2 activates SO_REUSEPORT #2 socket, fd: 23
2025-05-22 22:42:19.948945 [INFO] [876] Close SO_REUSEPORT #1 fd: 22.
2025-05-22 22:42:19.948973 [INFO] [874] Close SO_REUSEPORT #1 fd: 26.
2025-05-22 22:42:19.948979 [INFO] [876] Close SO_REUSEPORT #2 fd: 23.
2025-05-22 22:42:19.948980 [INFO] [874] Close SO_REUSEPORT #3 fd: 28.
2025-05-22 22:42:19.948986 [INFO] [874] Close SO_REUSEPORT #4 fd: 29.
2025-05-22 22:42:19.948985 [INFO] [876] Close SO_REUSEPORT #3 fd: 24.
2025-05-22 22:42:19.948990 [NOTICE] [874] [*:443] Worker #2 activates SO_REUSEPORT #2 socket, fd: 27
2025-05-22 22:42:19.948995 [INFO] [874] Close SO_REUSEPORT #1 fd: 30.
2025-05-22 22:42:19.948993 [NOTICE] [876] [*:80] Worker #4 activates SO_REUSEPORT #4 socket, fd: 25
2025-05-22 22:42:19.948999 [INFO] [874] Close SO_REUSEPORT #3 fd: 32.
2025-05-22 22:42:19.949004 [INFO] [874] Close SO_REUSEPORT #4 fd: 33.
2025-05-22 22:42:19.949009 [NOTICE] [874] [UDP *:443] Worker #2 activates SO_REUSEPORT #2 socket, fd: 31
2025-05-22 22:42:19.949014 [INFO] [876] Close SO_REUSEPORT #1 fd: 26.
2025-05-22 22:42:19.949024 [INFO] [876] Close SO_REUSEPORT #2 fd: 27.
2025-05-22 22:42:19.949029 [INFO] [876] Close SO_REUSEPORT #3 fd: 28.
2025-05-22 22:42:19.949035 [NOTICE] [876] [*:443] Worker #4 activates SO_REUSEPORT #4 socket, fd: 29
2025-05-22 22:42:19.949034 [INFO] [874] [UDP:0.0.0.0:443] initPacketsIn: allocated 100 packets
2025-05-22 22:42:19.949044 [INFO] [876] Close SO_REUSEPORT #1 fd: 30.
2025-05-22 22:42:19.949050 [INFO] [876] Close SO_REUSEPORT #2 fd: 31.
2025-05-22 22:42:19.949055 [INFO] [876] Close SO_REUSEPORT #3 fd: 32.
2025-05-22 22:42:19.949055 [INFO] [874] Close SO_REUSEPORT #1 fd: 34.
2025-05-22 22:42:19.949061 [NOTICE] [876] [UDP *:443] Worker #4 activates SO_REUSEPORT #4 socket, fd: 33
2025-05-22 22:42:19.949068 [INFO] [874] Close SO_REUSEPORT #3 fd: 36.
2025-05-22 22:42:19.949074 [INFO] [874] Close SO_REUSEPORT #4 fd: 37.
2025-05-22 22:42:19.949077 [NOTICE] [874] [[::]:443] Worker #2 activates SO_REUSEPORT #2 socket, fd: 35
2025-05-22 22:42:19.949084 [INFO] [874] Close SO_REUSEPORT #1 fd: 38.
2025-05-22 22:42:19.949087 [INFO] [874] Close SO_REUSEPORT #3 fd: 40.
2025-05-22 22:42:19.949091 [INFO] [876] [UDP:0.0.0.0:443] initPacketsIn: allocated 100 packets
2025-05-22 22:42:19.949092 [INFO] [874] Close SO_REUSEPORT #4 fd: 41.
2025-05-22 22:42:19.949104 [NOTICE] [874] [UDP [::]:443] Worker #2 activates SO_REUSEPORT #2 socket, fd: 39
2025-05-22 22:42:19.949108 [INFO] [876] Close SO_REUSEPORT #1 fd: 34.
2025-05-22 22:42:19.949116 [INFO] [876] Close SO_REUSEPORT #2 fd: 35.
2025-05-22 22:42:19.949120 [INFO] [874] [UDP:[::]:443] initPacketsIn: allocated 100 packets
2025-05-22 22:42:19.949122 [INFO] [876] Close SO_REUSEPORT #3 fd: 36.
2025-05-22 22:42:19.949132 [NOTICE] [876] [[::]:443] Worker #4 activates SO_REUSEPORT #4 socket, fd: 37
2025-05-22 22:42:19.949133 [NOTICE] [874] Stop listener *:7080, fd 20.
2025-05-22 22:42:19.949141 [INFO] [876] Close SO_REUSEPORT #1 fd: 38.
2025-05-22 22:42:19.949147 [INFO] [876] Close SO_REUSEPORT #2 fd: 39.
2025-05-22 22:42:19.949152 [INFO] [876] Close SO_REUSEPORT #3 fd: 40.
2025-05-22 22:42:19.949157 [NOTICE] [876] [UDP [::]:443] Worker #4 activates SO_REUSEPORT #4 socket, fd: 41
2025-05-22 22:42:19.949168 [INFO] [876] [UDP:[::]:443] initPacketsIn: allocated 100 packets
2025-05-22 22:42:19.949181 [NOTICE] [876] Stop listener *:7080, fd 20.
2025-05-22 22:42:19.949287 [NOTICE] [875] LiteSpeed/1.8.3 Open starts successfully!
2025-05-22 22:42:19.949309 [NOTICE] [874] Successfully change current user to nobody
2025-05-22 22:42:19.949322 [NOTICE] [874] Core dump is enabled.
2025-05-22 22:42:19.949337 [NOTICE] [874] Setup swapping space...
2025-05-22 22:42:19.949402 [NOTICE] [876] Successfully change current user to nobody
2025-05-22 22:42:19.949421 [NOTICE] [876] Core dump is enabled.
2025-05-22 22:42:19.949455 [NOTICE] [876] Setup swapping space...
2025-05-22 22:42:19.949589 [NOTICE] [874] LiteSpeed/1.8.3 Open starts successfully!
2025-05-22 22:42:19.949701 [INFO] [873] [lsphp]: locked pid file [/tmp/lshttpd/lsphp.sock.pid].
2025-05-22 22:42:19.949724 [INFO] [873] [lsphp] remove unix socket for detached process: /tmp/lshttpd/lsphp.sock
2025-05-22 22:42:19.949820 [NOTICE] [873] [LocalWorker::workerExec] Config[lsphp]: suExec uid 65534 gid 65534 cmd /usr/local/lsws/lsphp74/bin/lsphp, final uid 65534 gid 65534, flags: 0.
2025-05-22 22:42:19.949944 [NOTICE] [876] LiteSpeed/1.8.3 Open starts successfully!
2025-05-22 22:42:19.950294 [NOTICE] [873] [lsphp] add child process pid: 877
2025-05-22 22:42:19.950355 [INFO] [873] [lsphp]: unlocked pid file [/tmp/lshttpd/lsphp.sock.pid].
2025-05-22 22:42:19.950734 [INFO] [873] [porta6114.655340]: locked pid file [/tmp/lshttpd/porta6114.sock.pid].
2025-05-22 22:42:19.950747 [INFO] [873] [porta6114.655340] remove unix socket for detached process: /tmp/lshttpd/porta6114.sock
2025-05-22 22:42:19.950819 [NOTICE] [873] [LocalWorker::workerExec] VHost:portaleducadora.com suExec check uid 65534 gid 65534 setuidmode 0.
2025-05-22 22:42:19.950830 [NOTICE] [873] [LocalWorker::workerExec] Config[porta6114.655340]: suExec uid 2004 gid 2004 cmd /usr/local/lsws/lsphp74/bin/lsphp, final uid 2004 gid 2004, flags: 0.
2025-05-22 22:42:19.951056 [NOTICE] [873] [porta6114.655340] add child process pid: 879
2025-05-22 22:42:19.951109 [INFO] [873] [porta6114.655340]: unlocked pid file [/tmp/lshttpd/porta6114.sock.pid].
2025-05-22 22:42:19.951960 [INFO] [873] [wppor4085.655340]: locked pid file [/tmp/lshttpd/wppor4085.sock.pid].
2025-05-22 22:42:19.951973 [INFO] [873] [wppor4085.655340] remove unix socket for detached process: /tmp/lshttpd/wppor4085.sock
2025-05-22 22:42:19.952034 [NOTICE] [873] [LocalWorker::workerExec] VHost:wp.portaleducadora.com suExec check uid 65534 gid 65534 setuidmode 0.
2025-05-22 22:42:19.952048 [NOTICE] [873] [LocalWorker::workerExec] Config[wppor4085.655340]: suExec uid 2003 gid 2003 cmd /usr/local/lsws/lsphp80/bin/lsphp, final uid 2003 gid 2003, flags: 0.
2025-05-22 22:42:19.952243 [NOTICE] [873] [wppor4085.655340] add child process pid: 880
2025-05-22 22:42:19.952287 [INFO] [873] [wppor4085.655340]: unlocked pid file [/tmp/lshttpd/wppor4085.sock.pid].
2025-05-22 22:42:19.952314 [NOTICE] [873] Setup swapping space...
2025-05-22 22:42:19.952682 [NOTICE] [873] LiteSpeed/1.8.3 Open starts successfully!
journalctl -u lscpd -n 100 --no-pager
[root@wp bin]# journalctl -u lscpd -n 100 --no-pager
All services appear to be running normally, and I haven’t found any errors in the logs I checked. Is there anything else I can try?
Tks!
