I talked to my boss and when we fix the 404 problem we will try to extract the sites from the multisite, at the moment how can I continue ???
There needs to be thorough check on the vhost configuration, htaccess, openlitespeed configs, website paths, and lot more to find the cause of this issue and needs to be rectified.
What you can do currently is take backup of the public_html files and the database for each website and restore it manually on a fresh server to get the sites back online.
if I buy the cyberpanel support can they reset a backup or I have a greater speed in solving the problem or what do you recommend me to do?
At the moment my priority is to get the websites back online and migrating the databases of the two sites that weigh 5gb is not easily doable.
Greater speed in solving is not guaranteed by anyone as the solution of a problem depends on case to case. Time will be consumed to identify the issue and then to resolve the issue.
“Reset a backup” as you mentioned, are you sure the backup doesnt have issues?
5GB is not an impossible thing and can be done using the SSH commands. Although it will take its own time.
but i not able with ssh command line
whats the issue?
i solved the problem with paid support, thanks
Resolved on support
