Hello! No matter what I do, there is always a 403 on my website (most likely a webserver issue), and I tried to fix the permission, but that did not work either.
DO you have modsecurity on your server?
I believe so.
Hello @VexusitySzolgaltatas Happy you are here
First enable dynamic logging Troubleshooting CyberPanel - Docs - CyberPanel Community
Post contents of /home/cyberpanel/error-logs.txt when you visit said website
Possible causes:
- Fualty php
- Bug in your website code
- Modsecurity issue with WordPress
Fix: Go to Security → ModSecurity Rules and add the following code
<locationmatch "/wp-admin/admin-ajax.php">
SecRuleRemoveById 300013
SecRuleRemoveById 300015
SecRuleRemoveById 300016
SecRuleRemoveById 300017
SecRuleRemoveById 949110
SecRuleRemoveById 980130
</locationmatch>
- Fix Permissions
Fix: Go to Websites → mywebsite.com → File Manager → Fix Permissions
- Chech your .htaccess if you changed anything or added anything. Post contents here if you believe you changed anything
Thank you all for the help! What should I do if I don’t have ModSecurity? Some people have it installed, and some don’t, and that’s why I’m asking.
you use website using another folder or just public_html ?
if another folder , rename that folder like to folder_bk
then open website->manage->select you website , open vhost conf, make sure the doc root same then before , and press save , it will make a new folder like before
copy file from folder_bk to the that folder
