Do you plan to upgrade to MariaDB 10.4 ?
With CyberPanel, MariaDB 10.1 is installed.
Are you planning to upgrade to MariaDB 10.4 ?
Thank you
As an alternative, you can also update to MariaDB 10.4 yourself. If you search the forums, there are guides for doing this.
See below:
After upgrading, I ran into an issue where MariaDB would not automatically start at VPS bootup. The fix below works if you should run into that same problem:
https://community.centminmod.com/threads/mariadb-10-1-16-unable-to-restart-fix.8071/
