I have 48 domains. I left cpanel and shifted to cyberpanel
Which domain ? the primary domain of the server ?
Did you create private nameservers for the primary domain ?
primary domain matkasolution.com
This domain is ok it points to 64.227.xxx is this your server where cyberpanel is installed ?
but sir other domain is not getting point on this server
Did you setup these domains with correct ns records ?
Shall I give you the login details of my server so that you can check that I have done everything correctly
