Hi all,
I’ve recently expiriencing some issue after apt upgrade on my ubuntu machine. Cyberpanel itself and all websites work fine. I’m able to add/remove websites, add/remove dns entries, issue ssl etc.
But when I try to change htaccess file or look at the logs site comes back with django error.
Provider: OneProvider
Virtualization Type: N/A it’s dedicated server
System: Ubuntu 18.04
Installation option:
OLS
official
no
yes
Install LiteSpeed Memcached?
yes
Install Memcached?
yes
yes
Install Redis?
yes
When trying to save htaccess
Could not save rewrite rules. Error message: Traceback (most recent call last): File “/usr/local/CyberCP/plogical/virtualHostUtilities.py”, line 26, in from vhost import vhost File “/usr/local/CyberCP/plogical/vhost.py”, line 23, in from managePHP.phpManager import PHPManager File “/usr/local/CyberCP/managePHP/phpManager.py”, line 6, in from .models import * File “/usr/local/CyberCP/managePHP/models.py”, line 9, in class PHP(models.Model): File “/usr/local/CyberCP/managePHP/models.py”, line 10, in PHP phpVers = models.CharField(max_length=5,unique=True) File “/usr/local/CyberCP/local/lib/python2.7/site-packages/django/db/models/fields/init.py”, line 1057, in init super(CharField, self).init(*args, **kwargs) File “/usr/local/CyberCP/local/lib/python2.7/site-packages/django/db/models/fields/init.py”, line 172, in init self.db_tablespace = db_tablespace or settings.DEFAULT_INDEX_TABLESPACE File “/usr/local/CyberCP/local/lib/python2.7/site-packages/django/conf/init.py”, line 56, in getattr self._setup(name) File “/usr/local/CyberCP/local/lib/python2.7/site-packages/django/conf/init.py”, line 41, in _setup self._wrapped = Settings(settings_module) File “/usr/local/CyberCP/local/lib/python2.7/site-packages/django/conf/init.py”, line 110, in init mod = importlib.import_module(self.SETTINGS_MODULE) File “/usr/lib/python2.7/importlib/init.py”, line 37, in import_module import(name) ImportError: No module named settings
When trying to access site logs
self._setup(name)
import(name)
Alto I do have full rsync backup from when it was still working, I would like to know if that’s something that’s someone already seen and is fixible
Thank you.
