Looks very interesting, Ive just installed it to give it a test. well to see what it looks like on a vps, going to buy a dedicated server soon to test the creation of vps servers.
I notice its in the ent docs and not the normal docs, so i’ll assume it’ll be only usable for the enterprise users and not the free one when it comes out of beta?
i like the fact you can create vpses on other servers from one panel with other servers having cyberpanel on to, Might be a idea to add that feature for the hosting and reseller part to
I ment on the vps panel part you can add other servers and create vpses on other severs youve added to the main vps panel under server then create server.
what i ment is the same for the normal panel where you can add servers to the main host panel and create shared and reseller accounts onto other servers from the main panel like you can with the vps panel
