As seen below, the upgrade process fails because it does not account for scenarios when CSF is not installed. It would be great if this upgrade process was better tested before being released.
[02.07.2025_06-32-22] #########################################################################
[02.07.2025_06-32-22] fix csf if there successful.
Restoring files...
File "/root/cyberpanel_upgrade_tmp/upgrade.py", line 3983, in <module>
main()
File "/root/cyberpanel_upgrade_tmp/upgrade.py", line 3979, in main
Upgrade.upgrade(args.branch)
File "/root/cyberpanel_upgrade_tmp/upgrade.py", line 3610, in upgrade
restore_files()
File "/root/cyberpanel_upgrade_tmp/upgrade.py", line 3592, in restore_files
shutil.copy(backup_file, file)
File "/usr/lib/python3.10/shutil.py", line 417, in copy
copyfile(src, dst, follow_symlinks=follow_symlinks)
File "/usr/lib/python3.10/shutil.py", line 256, in copyfile
with open(dst, 'wb') as fdst:
FileNotFoundError: [Errno 2] No such file or directory: '/etc/csf/csf.allow'
above command failed...
