Cyberpanel after upgrade not working, Goto port 8090 Browser say: ERR_SSL_PROTOCOL_ERROR
Version 1.9
After trying to upgrade again and still got the above error, what should I do
Version 1.9
Secure Connection Failed
An error occurred during a connection to domain.com:8090. SSL received a record that exceeded the maximum permissible length. Error code: SSL_ERROR_RX_RECORD_TOO_LONG
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the website owners to inform them of this problem.
Loaded plugins: fastestmirror
No Packages marked for removal
Changing shell for cyberpanel.
All settings correct for using Composer
Downloading...
Composer (version 1.9.0) successfully installed to: /usr/local/composer.phar
Use it: php composer.phar
Requirement already satisfied (use --upgrade to upgrade): pydns in /usr/lib/python2.7/site-packages
[04-43-32-Fri-Oct-2019] #########################################################################
[04-43-32-Fri-Oct-2019] remove yum-plugin-priorities successful.
[04-43-32-Fri-Oct-2019] stop lscpd successful.
[04-43-32-Fri-Oct-2019] adduser docker failed, trying again, try number: 1
[04-43-32-Fri-Oct-2019] adduser docker failed, trying again, try number: 2
[04-43-32-Fri-Oct-2019] adduser docker failed, trying again, try number: 3
[04-43-32-Fri-Oct-2019] adduser docker failed.
[04-43-32-Fri-Oct-2019] adduser docker successful.
[04-43-41-Fri-Oct-2019] #########################################################################
[04-43-41-Fri-Oct-2019] Install PyDNS successful.
[04-43-57-Fri-Oct-2019] #########################################################################
[04-43-57-Fri-Oct-2019] Download latest version successful.
[04-43-57-Fri-Oct-2019] Backing up settings file.
[04-43-57-Fri-Oct-2019] Settings file backed uRequirement already satisfied (use --upgrade to upgrade): tldextract in /usr/lib/python2.7/site-packages
Requirement already satisfied (use --upgrade to upgrade): idna in /usr/lib/python2.7/site-packages (from tldextract)
Requirement already satisfied (use --upgrade to upgrade): requests-file>=1.4 in /usr/lib/python2.7/site-packages (from tldextract)
Requirement already satisfied (use --upgrade to upgrade): setuptools in /usr/lib/python2.7/site-packages (from tldextract)
Requirement already satisfied (use --upgrade to upgrade): requests>=2.1.0 in /usr/lib/python2.7/site-packages (from tldextract)
Requirement already satisfied (use --upgrade to upgrade): six in /usr/lib/python2.7/site-packages (from requests-file>=1.4->tldextract)
Requirement already satisfied (use --upgrade to upgrade): chardet<3.1.0,>=3.0.2 in /usr/lib/python2.7/site-packages (from requests>=2.1.0->tldextract)
Requirement already satisfied (use --upgrade to upgrade): urllib3<1.23,>=1.21.1 in /usr/lib/python2.7/site-packages (from requests>=2.1.0->tldextract)
Requirement already satisfied (use --upgrade to upgrade): certifi>=2017.4.17 in /usr/lib/python2.7/site-packages (from requests>=2.1.0->tldextract)
Requirement already satisfied (use --upgrade to upgrade): bcrypt in /usr/lib64/python2.7/site-packages
Requirement already satisfied (use --upgrade to upgrade): cffi>=1.1 in /usr/lib64/python2.7/site-packages (from bcrypt)
Requirement already satisfied (use --upgrade to upgrade): six>=1.4.1 in /usr/lib/python2.7/site-packages (from bcrypt)
Requirement already satisfied (use --upgrade to upgrade): pycparser in /usr/lib/python2.7/site-packages (from cffi>=1.1->bcrypt)
* base: mirrors.nhanhoa.com
* epel: my.fedora.ipserverone.com
* extras: mirrors.nhanhoa.com
* updates: mirrors.nhanhoa.com
Package libattr-devel-2.4.46-13.el7.x86_64 already installed and latest version
Package xz-devel-5.2.2-1.el7.x86_64 already installed and latest version
Package gpgme-devel-1.3.2-5.el7.x86_64 already installed and latest version
Package 1:mariadb-devel-5.5.64-1.el7.x86_64 is obsoleted by MariaDB-devel-10.1.41-1.el7.centos.x86_64 which is already installed
Package libcurl-devel-7.29.0-54.el7.x86_64 already installed and latest version
Nothing to do
Nothing to do
Requirement already satisfied (use --upgrade to upgrade): virtualenv in /usr/lib/python2.7/site-packages
No LICENSE.txt / LICENSE found in source
New python executable in /usr/local/CyberCP/bin/python2
Also creating executable in /usr/local/CyberCP/bin/python
Installing setuptools, pip, wheel...
done.
Not overwriting existing python script /usr/local/CyberCP/bin/python (you must use /usr/local/CyberCP/bin/python2)
done.
Collecting acme==0.21.1 (from -r /usr/local/CyberCP/requirments.txt (line 1))
Using cached https://files.pythonhosted.org/packages/d8/83/d37e3598e8aff2e52d6e1b49aaae6cab548ca62595a4634c459c808b4557/acme-0.21.1-py2.py3-none-any.whl
Collecting asn1crypto==0.24.0 (from -r /usr/local/CyberCP/requirments.txt (line 2))
Using cached https://files.pythonhosted.org/packages/ea/cd/35485615f45f30a510576f1a56d1e0a7ad7bd8ab5ed7cdc600ef7cd06222/asn1crypto-0.24.0-py2.py3-none-any.whl
Collecting Babel==0.9.6 (from -r /usr/local/CyberCP/requirments.txt (line 3))
Collecting bcrypt==3.1.7 (from -r /usr/local/CyberCP/requirments.txt (line 4))
Using cached https://files.pythonhosted.org/packages/ad/36/9a0227d048e98409f012570f7bef8a8c2373b9c9c5dfbf82963cbae05ede/bcrypt-3.1.7-cp27-cp27mu-manylinux1_x86_64.whl
Collecting backports.ssl-match-hostname==3.5.0.1 (from -r /usr/local/CyberCP/requirments.txt (line 5))
Collecting boto3==1.9.64 (from -r /usr/local/CyberCP/requirments.txt (line 6))
Using cached https://files.pythonhosted.org/packages/5c/3a/da62fd31ae6154fe32485f067c4ef9a3dc65880fee9d2b189a1d6c17def8/boto3-1.9.64-py2.py3-none-any.whl
Collecting botocore==1.12.64 (from -r /usr/local/CyberCP/requirments.txt (line 7))
Using cached https://files.pythonhosted.org/packages/98/8b/490e56b674f9a4cc750ae3588dcf300a57b84f7d1f80daf0b21b3e4f1d1f/botocore-1.12.64-py2.py3-none-any.whl
Collecting certbot==0.21.1 (from -r /usr/local/CyberCP/requirments.txt (line 8))
Using cached https://files.pythonhosted.org/packages/47/16/d49ff6ddd86ea57affa7e927797932bec1f9e5f2c9fa49a429ad2aac1b96/certbot-0.21.1-py2.py3-none-any.whl
Collecting certifi==2018.4.16 (from -r /usr/local/CyberCP/requirments.txt (line 9))
Using cached https://files.pythonhosted.org/packages/7c/e6/92ad559b7192d846975fc916b65f667c7b8c3a32bea7372340bfe9a15fa5/certifi-2018.4.16-py2.py3-none-any.whl
Collecting cffi==1.11.5 (from -r /usr/local/CyberCP/requirments.txt (line 10))
Using cached https://files.pythonhosted.org/packages/14/dd/3e7a1e1280e7d767bd3fa15791759c91ec19058ebe31217fe66f3e9a8c49/cffi-1.11.5-cp27-cp27mu-manylinux1_x86_64.whl
Collecting chardet==3.0.4 (from -r /usr/local/CyberCP/requirments.txt (line 11))
Using cached https://files.pythonhosted.org/packages/bc/a9/01ffebfb562e4274b6487b4bb1ddec7ca55ec7510b22e4c51f14098443b8/chardet-3.0.4-py2.py3-none-any.whl
Collecting ConfigArgParse==0.13.0 (from -r /usr/local/CyberCP/requirments.txt (line 12))
Collecting configobj==4.7.2 (from -r /usr/local/CyberCP/requirments.txt (line 13))
Collecting cryptography==2.2.2 (from -r /usr/local/CyberCP/requirments.txt (line 14))
Using cached https://files.pythonhosted.org/packages/dd/c2/3a5bfefb25690725824ade71e6b65449f0a9f4b29702cce10560f786ebf6/cryptography-2.2.2-cp27-cp27mu-manylinux1_x86_64.whl
Collecting decorator==3.4.0 (from -r /usr/local/CyberCP/requirments.txt (line 15))
Collecting docker==3.6.0 (from -r /usr/local/CyberCP/requirments.txt (line 16))
Using cached https://files.pythonhosted.org/packages/e1/58/938fbc7acd98302ca4872f5eab8ab811498e342ab5aec0c1609f22e0aeda/docker-3.6.0-py2.py3-none-any.whl
Collecting docker-pycreds==0.4.0 (from -r /usr/local/CyberCP/requirments.txt (line 17))
Using cached https://files.pythonhosted.org/packages/f5/e8/f6bd1eee09314e7e6dee49cbe2c5e22314ccdb38db16c9fc72d2fa80d054/docker_pycreds-0.4.0-py2.py3-none-any.whl
Collecting Django==1.11 (from -r /usr/local/CyberCP/requirments.txt (line 18))
Using cached https://files.pythonhosted.org/packages/47/a6/078ebcbd49b19e22fd560a2348cfc5cec9e5dcfe3c4fad8e64c9865135bb/Django-1.11-py2.py3-none-any.whl
Collecting docutils==0.14 (from -r /usr/local/CyberCP/requirments.txt (line 19))
Using cached https://files.pythonhosted.org/packages/50/09/c53398e0005b11f7ffb27b7aa720c617aba53be4fb4f4f3f06b9b5c60f28/docutils-0.14-py2-none-any.whl
Collecting enum34==1.1.6 (from -r /usr/local/CyberCP/requirments.txt (line 20))
Using cached https://files.pythonhosted.org/packages/c5/db/e56e6b4bbac7c4a06de1c50de6fe1ef3810018ae11732a50f15f62c7d050/enum34-1.1.6-py2-none-any.whl
Collecting funcsigs==1.0.2 (from -r /usr/local/CyberCP/requirments.txt (line 21))
Using cached https://files.pythonhosted.org/packages/69/cb/f5be453359271714c01b9bd06126eaf2e368f1fddfff30818754b5ac2328/funcsigs-1.0.2-py2.py3-none-any.whl
Collecting future==0.16.0 (from -r /usr/local/CyberCP/requirments.txt (line 22))
Collecting futures==3.2.0 (from -r /usr/local/CyberCP/requirments.txt (line 23))
Using cached https://files.pythonhosted.org/packages/2d/99/b2c4e9d5a30f6471e410a146232b4118e697fa3ffc06d6a65efde84debd0/futures-3.2.0-py2-none-any.whl
Collecting idna==2.6 (from -r /usr/local/CyberCP/requirments.txt (line 24))
Using cached https://files.pythonhosted.org/packages/27/cc/6dd9a3869f15c2edfab863b992838277279ce92663d334df9ecf5106f5c6/idna-2.6-py2.py3-none-any.whl
Collecting iniparse==0.4 (from -r /usr/local/CyberCP/requirments.txt (line 25))
Collecting ipaddress==1.0.16 (from -r /usr/local/CyberCP/requirments.txt (line 26))
Using cached https://files.pythonhosted.org/packages/23/6a/813ac29a01e4c33c19c2bded98ac3d4266ebbf0bd2c0eb0020e1c969958d/ipaddress-1.0.16-py27-none-any.whl
Collecting IPy==0.75 (from -r /usr/local/CyberCP/requirments.txt (line 27))
Collecting Jinja2==2.7.2 (from -r /usr/local/CyberCP/requirments.txt (line 28))
Collecting jmespath==0.9.3 (from -r /usr/local/CyberCP/requirments.txt (line 29))
Using cached https://files.pythonhosted.org/packages/b7/31/05c8d001f7f87f0f07289a5fc0fc3832e9a57f2dbd4d3b0fee70e0d51365/jmespath-0.9.3-py2.py3-none-any.whl
Collecting josepy==1.1.0 (from -r /usr/local/CyberCP/requirments.txt (line 30))
Using cached https://files.pythonhosted.org/packages/23/46/30ac29742b03be92e05d1fd9048df6f0902bb0b3b042a7ea76a2b3c30f7e/josepy-1.1.0-py2.py3-none-any.whl
Collecting jsonpatch==1.2 (from -r /usr/local/CyberCP/requirments.txt (line 31))
Collecting jsonpointer==1.9 (from -r /usr/local/CyberCP/requirments.txt (line 32))
Using cached https://files.pythonhosted.org/packages/e9/79/683a3318610ad3d950d3fadd25c0b76923b749d0ba828a9466150ac641ac/jsonpointer-1.9-py2-none-any.whl
Collecting kitchen==1.1.1 (from -r /usr/local/CyberCP/requirments.txt (line 33))
Collecting MarkupSafe==0.11 (from -r /usr/local/CyberCP/requirments.txt (line 34))
Collecting mock==2.0.0 (from -r /usr/local/CyberCP/requirments.txt (line 35))
Using cached https://files.pythonhosted.org/packages/e6/35/f187bdf23be87092bd0f1200d43d23076cee4d0dec109f195173fd3ebc79/mock-2.0.0-py2.py3-none-any.whl
Collecting parsedatetime==2.4 (from -r /usr/local/CyberCP/requirments.txt (line 36))
Using cached https://files.pythonhosted.org/packages/1d/48/ac8d4c6239437592852e951bcb9438dc585f80c29777c391aef69c67dc79/parsedatetime-2.4-py2-none-any.whl
Collecting pbr==4.0.4 (from -r /usr/local/CyberCP/requirments.txt (line 37))
Using cached https://files.pythonhosted.org/packages/b3/5d/c196041ffdf3e34ba206db6d61d1f893a75e1f3435699ade9bd65e089a3d/pbr-4.0.4-py2.py3-none-any.whl
Collecting pexpect==4.4.0 (from -r /usr/local/CyberCP/requirments.txt (line 38))
Using cached https://files.pythonhosted.org/packages/05/80/3a8f823aadc85a8ba3744d95ba591cbe999fbca5d97429a056fd82c4ea92/pexpect-4.4.0-py2.py3-none-any.whl
Collecting prettytable==0.7.2 (from -r /usr/local/CyberCP/requirments.txt (line 39))
Collecting psutil==5.4.3 (from -r /usr/local/CyberCP/requirments.txt (line 40))
Collecting ptyprocess==0.6.0 (from -r /usr/local/CyberCP/requirments.txt (line 41))
Using cached https://files.pythonhosted.org/packages/d1/29/605c2cc68a9992d18dada28206eeada56ea4bd07a239669da41674648b6f/ptyprocess-0.6.0-py2.py3-none-any.whl
Collecting pycparser==2.18 (from -r /usr/local/CyberCP/requirments.txt (line 42))
Collecting pycurl==7.19.0 (from -r /usr/local/CyberCP/requirments.txt (line 43))
Collecting pydns==2.3.6 (from -r /usr/local/CyberCP/requirments.txt (line 44))
Collecting pygpgme==0.3 (from -r /usr/local/CyberCP/requirments.txt (line 45))
Collecting pyliblzma==0.5.3 (from -r /usr/local/CyberCP/requirments.txt (line 46))
Collecting pyOpenSSL==17.5.0 (from -r /usr/local/CyberCP/requirments.txt (line 47))
Using cached https://files.pythonhosted.org/packages/79/db/7c0cfe4aa8341a5fab4638952520d8db6ab85ff84505e12c00ea311c3516/pyOpenSSL-17.5.0-py2.py3-none-any.whl
Collecting pyRFC3339==1.1 (from -r /usr/local/CyberCP/requirments.txt (line 48))
Using cached https://files.pythonhosted.org/packages/c1/7a/725f5c16756ec6211b1e7eeac09f469084595513917ea069bc023c40a5e2/pyRFC3339-1.1-py2.py3-none-any.whl
Collecting pyserial==2.6 (from -r /usr/local/CyberCP/requirments.txt (line 49))
Collecting python-dateutil==2.7.5 (from -r /usr/local/CyberCP/requirments.txt (line 50))
Using cached https://files.pythonhosted.org/packages/74/68/d87d9b36af36f44254a8d512cbfc48369103a3b9e474be9bdfe536abfc45/python_dateutil-2.7.5-py2.py3-none-any.whl
Collecting pytz==2018.4 (from -r /usr/local/CyberCP/requirments.txt (line 51))
Using cached https://files.pythonhosted.org/packages/dc/83/15f7833b70d3e067ca91467ca245bae0f6fe56ddc7451aa0dc5606b120f2/pytz-2018.4-py2.py3-none-any.whl
Collecting pyudev==0.15 (from -r /usr/local/CyberCP/requirments.txt (line 52))
Collecting pyxattr==0.5.1 (from -r /usr/local/CyberCP/requirments.txt (line 53))
Collecting PyYAML==3.10 (from -r /usr/local/CyberCP/requirments.txt (line 54))
Collecting requests==2.18.4 (from -r /usr/local/CyberCP/requirments.txt (line 55))
Using cached https://files.pythonhosted.org/packages/49/df/50aa1999ab9bde74656c2919d9c0c085fd2b3775fd3eca826012bef76d8c/requests-2.18.4-py2.py3-none-any.whl
Collecting requests-file==1.4.3 (from -r /usr/local/CyberCP/requirments.txt (line 56))
Using cached https://files.pythonhosted.org/packages/23/9c/6e63c23c39e53d3df41c77a3d05a49a42c4e1383a6d2a5e3233161b89dbf/requests_file-1.4.3-py2.py3-none-any.whl
Collecting s3transfer==0.1.13 (from -r /usr/local/CyberCP/requirments.txt (line 57))
Using cached https://files.pythonhosted.org/packages/d7/14/2a0004d487464d120c9fb85313a75cd3d71a7506955be458eebfe19a6b1d/s3transfer-0.1.13-py2.py3-none-any.whl
Collecting six==1.9.0 (from -r /usr/local/CyberCP/requirments.txt (line 58))
Using cached https://files.pythonhosted.org/packages/10/e3/a7f8eea80a9fa8358c1cd89ef489bc03675e69e54ed2982cd6f2a28d8295/six-1.9.0-py2.py3-none-any.whl
Collecting tldextract==2.2.0 (from -r /usr/local/CyberCP/requirments.txt (line 59))
Using cached https://files.pythonhosted.org/packages/0e/0c/1b7332684dfc2e6311d59cd00859a5318a7e0ba50334ad217ceb9555e213/tldextract-2.2.0-py2.py3-none-any.whl
Collecting urllib3==1.22 (from -r /usr/local/CyberCP/requirments.txt (line 60))
Using cached https://files.pythonhosted.org/packages/63/cb/6965947c13a94236f6d4b8223e21beb4d576dc72e8130bd7880f600839b8/urllib3-1.22-py2.py3-none-any.whl
Collecting zope.component==4.4.1 (from -r /usr/local/CyberCP/requirments.txt (line 61))
Using cached https://files.pythonhosted.org/packages/b6/e8/6eb8e2c6e856fb9bfe842afe01695da53d046fd5ddee358cde24d8aab31f/zope.component-4.4.1-py2.py3-none-any.whl
Collecting zope.event==4.3.0 (from -r /usr/local/CyberCP/requirments.txt (line 62))
Using cached https://files.pythonhosted.org/packages/03/62/bb2d843b59f62bac43d071e2d3543ffc63d35fcc515a5796c759b62de49b/zope.event-4.3.0-py2.py3-none-any.whl
Collecting zope.interface==4.5.0 (from -r /usr/local/CyberCP/requirments.txt (line 63))
Using cached https://files.pythonhosted.org/packages/cd/14/55694f6289425d1cd41c59cf0aaf0188686b5b544140cab64c6f9e508751/zope.interface-4.5.0-cp27-cp27mu-manylinux1_x86_64.whl
Collecting setuptools>=1.0 (from acme==0.21.1->-r /usr/local/CyberCP/requirments.txt (line 1))
Using cached https://files.pythonhosted.org/packages/b2/86/095d2f7829badc207c893dd4ac767e871f6cd547145df797ea26baea4e2e/setuptools-41.2.0-py2.py3-none-any.whl
Collecting websocket-client>=0.32.0 (from docker==3.6.0->-r /usr/local/CyberCP/requirments.txt (line 16))
Using cached https://files.pythonhosted.org/packages/29/19/44753eab1fdb50770ac69605527e8859468f3c0fd7dc5a76dd9c4dbd7906/websocket_client-0.56.0-py2.py3-none-any.whl
Installing collected packages: six, idna, pycparser, cffi, enum34, asn1crypto, ipaddress, cryptography, pyOpenSSL, setuptools, urllib3, chardet, certifi, requests, josepy, pytz, funcsigs, pbr, mock, pyRFC3339, acme, Babel, bcrypt, backports.ssl-match-hostname, jmespath, futures, docutils, python-dateutil, botocore, s3transfer, boto3, ConfigArgParse, configobj, zope.interface, future, parsedatetime, zope.event, zope.component, certbot, decorator, websocket-client, docker-pycreds, docker, Django, iniparse, IPy, MarkupSafe, Jinja2, jsonpointer, jsonpatch, kitchen, ptyprocess, pexpect, prettytable, psutil, pycurl, pydns, pygpgme, pyliblzma, pyserial, pyudev, pyxattr, PyYAML, requests-file, tldextract
Successfully installed Babel-0.9.6 ConfigArgParse-0.13.0 Django-1.11 IPy-0.75 Jinja2-2.7.2 MarkupSafe-0.11 PyYAML-3.10 acme-0.21.1 asn1crypto-0.24.0 backports.ssl-match-hostname-3.5.0.1 bcrypt-3.1.7 boto3-1.9.64 botocore-1.12.64 certbot-0.21.1 certifi-2018.4.16 cffi-1.11.5 chardet-3.0.4 configobj-4.7.2 cryptography-2.2.2 decorator-3.4.0 docker-3.6.0 docker-pycreds-0.4.0 docutils-0.14 enum34-1.1.6 funcsigs-1.0.2 future-0.16.0 futures-3.2.0 idna-2.6 iniparse-0.4 ipaddress-1.0.16 jmespath-0.9.3 josepy-1.1.0 jsonpatch-1.2 jsonpointer-1.9 kitchen-1.1.1 mock-2.0.0 parsedatetime-2.4 pbr-4.0.4 pexpect-4.4.0 prettytable-0.7.2 psutil-5.4.3 ptyprocess-0.6.0 pyOpenSSL-17.5.0 pyRFC3339-1.1 pycparser-2.18 pycurl-7.19.0 pydns-2.3.6 pygpgme-0.3 pyliblzma-0.5.3 pyserial-2.6 python-dateutil-2.7.5 pytz-2018.4 pyudev-0.15 pyxattr-0.5.1 requests-2.18.4 requests-file-1.4.3 s3transfer-0.1.13 setuptools-41.2.0 six-1.9.0 tldextract-2.2.0 urllib3-1.22 websocket-client-0.56.0 zope.component-4.4.1 zope.event-4.3.0 zope.interface-4.5.0
done.
Package lsphp73-7.3.10-1.el7.x86_64 already installed and latest version
Package lsphp73-json-7.3.10-1.el7.x86_64 already installed and latest version
Package lsphp73-xmlrpc-7.3.10-1.el7.x86_64 already installed and latest version
Package lsphp73-xml-7.3.10-1.el7.x86_64 already installed and latest version
Package lsphp73-tidy-7.3.10-1.el7.x86_64 already installed and latest version
Package lsphp73-soap-7.3.10-1.el7.x86_64 already installed and latest version
Package lsphp73-snmp-7.3.10-1.el7.x86_64 already installed and latest version
Package lsphp73-recode-7.3.10-1.el7.x86_64 already installed and latest version
Package lsphp73-pspell-7.3.10-1.el7.x86_64 already installed and latest version
Package lsphp73-process-7.3.10-1.el7.x86_64 already installed and latest version
Package lsphp73-pgsql-7.3.10-1.el7.x86_64 already installed and latest version
Package 1:lsphp73-pear-1.10.7-1.el7.noarch already installed and latest version
Package lsphp73-pdo-7.3.10-1.el7.x86_64 already installed and latest version
Package lsphp73-opcache-7.3.10-1.el7.x86_64 already installed and latest version
Package lsphp73-odbc-7.3.10-1.el7.x86_64 already installed and latest version
Package lsphp73-mysqlnd-7.3.10-1.el7.x86_64 already installed and latest version
Package lsphp73-pecl-mcrypt-1.0.1-1.el7.7.3.x86_64 already installed and latest version
Package lsphp73-mbstring-7.3.10-1.el7.x86_64 already installed and latest version
Package lsphp73-ldap-7.3.10-1.el7.x86_64 already installed and latest version
Package lsphp73-intl-7.3.10-1.el7.x86_64 already installed and latest version
Package lsphp73-imap-7.3.10-1.el7.x86_64 already installed and latest version
Package lsphp73-gmp-7.3.10-1.el7.x86_64 already installed and latest version
Package lsphp73-gd-7.3.10-1.el7.x86_64 already installed and latest version
Package lsphp73-enchant-7.3.10-1.el7.x86_64 already installed and latest version
Package lsphp73-dba-7.3.10-1.el7.x86_64 already installed and latest version
Package lsphp73-common-7.3.10-1.el7.x86_64 already installed and latest version
Package lsphp73-bcmath-7.3.10-1.el7.x86_64 already installed and latest version
Nothing to do
p.
[04-43-59-Fri-Oct-2019] #########################################################################
[04-43-59-Fri-Oct-2019] Extract latest version successful.
[04-43-59-Fri-Oct-2019] Restoring settings file!
[04-43-59-Fri-Oct-2019] Settings file restored!
[04-43-59-Fri-Oct-2019] Remove old static content successful.
[04-44-10-Fri-Oct-2019] #########################################################################
[04-44-10-Fri-Oct-2019] Install tldextract successful.
[04-44-11-Fri-Oct-2019] #########################################################################
[04-44-11-Fri-Oct-2019] Install tldextract successful.
[04-44-11-Fri-Oct-2019] Setting up virtual environment for CyberPanel.
[04-44-12-Fri-Oct-2019] #########################################################################
[04-44-12-Fri-Oct-2019] VirtualEnv Pre-reqs successful.
[04-44-13-Fri-Oct-2019] #########################################################################
[04-44-13-Fri-Oct-2019] VirtualEnv Pre-reqs successful.
[04-44-14-Fri-Oct-2019] #########################################################################
[04-44-14-Fri-Oct-2019] VirtualEnv Install successful.
[04-44-19-Fri-Oct-2019] #########################################################################
[04-44-19-Fri-Oct-2019] Setting up VirtualEnv [One] successful.
[04-44-52-Fri-Oct-2019] #########################################################################
[04-44-52-Fri-Oct-2019] CyberPanel requirements successful.
[04-44-58-Fri-Oct-2019] #########################################################################
[04-44-58-Fri-Oct-2019] Setting up VirtualEnv [Two] successful.
[04-44-58-Fri-Oct-2019] Virtual enviroment for CyberPanel successfully installed.
[04-45-02-Fri-Oct-2019] #########################################################################
[04-45-02-Fri-Oct-2019] Install PHP 73, 0 successful.
[04-45-02-Fri-Oct-2019] ##############################################Done.
make: Nothing to be done for `all'.
Package gcc-4.8.5-39.el7.x86_64 already installed and latest version
Package gcc-c++-4.8.5-39.el7.x86_64 already installed and latest version
Package 1:make-3.82-24.el7.x86_64 already installed and latest version
Package autoconf-2.69-11.el7.noarch already installed and latest version
Package glibc-2.17-292.el7.x86_64 already installed and latest version
Package rcs-5.9.0-5.el7.x86_64 already installed and latest version
Nothing to do
Package pcre-devel-8.32-17.el7.x86_64 already installed and latest version
Package 1:openssl-devel-1.0.2k-19.el7.x86_64 already installed and latest version
Package expat-devel-2.1.0-10.el7_3.x86_64 already installed and latest version
Package GeoIP-devel-1.5.0-14.el7.x86_64 already installed and latest version
Package zlib-devel-1.2.7-18.el7.x86_64 already installed and latest version
Package udns-devel-0.4-3.el7.x86_64 already installed and latest version
Package which-2.20-7.el7.x86_64 already installed and latest version
Package curl-7.29.0-54.el7.x86_64 already installed and latest version
Nothing to do
[04-45-02-Fri-Oct-2019] CLI Symlink failed, trying again, try number: 1
[04-45-02-Fri-Oct-2019] CLI Symlink failed, trying again, try number: 2
[04-45-02-Fri-Oct-2019] CLI Symlink failed, trying again, try number: 3
[04-45-02-Fri-Oct-2019] CLI Symlink failed.
[04-45-02-Fri-Oct-2019] CLI Permissions successful.
[04-45-03-Fri-Oct-2019] #########################################################################
[04-45-03-Fri-Oct-2019] Starting LSCPD installation..
[04-45-04-Fri-Oct-2019] #########################################################################
[04-45-04-Fri-Oct-2019] LSCPD Pre-reqs [one] successful.
[04-45-10-Fri-Oct-2019] #########################################################################
[04-45-10-Fri-Oct-2019] LSCPD Download. successful.
[04-45-12-Fri-Oct-2019] #########################################################################
[04-45-12-Fri-Oct-2019] LSCPD Pre-reqs [two] successful.
[04-45-12-Fri-Oct-2019] Add user LSCPD failed, trying again, try number: 1
[04-45-12-Fri-Oct-2019] Add user LSCPD failed, trying again, try number: 2
[04-45-12-Fri-Oct-2019] Add user LSCPD failed, trying again, try number: 3
[04-45-12-Fri-Oct-2019] Add user LSCPD failed.
[04-45-12-Fri-Oct-2019] Add group LSCPD failed, trying again, try number: 1
[04-45-12-Fri-Oct-2019] Add group LSCPD failed, trying again, try number: 2
[04-45-12-Fri-Oct-2019] ####No changes detected
No changes detected
Metadata Cache Created
No packages marked for update
Resolving Dependencies
--> Running transaction check
---> Package postfix3.x86_64 2:3.4.7-1.gf.el7 will be erased
--> Processing Dependency: postfix3 = 2:3.4.7-1.gf.el7 for package: 2:postfix3-mysql-3.4.7-1.gf.el7.x86_64
---> Package postfix3-mysql.x86_64 2:3.4.7-1.gf.el7 will be erased
--> Finished Dependency Resolution
Dependencies Resolved
Package Arch Version Repository Size
Removing:
postfix3 x86_64 2:3.4.7-1.gf.el7 @gf-plus 10 M
Removing for dependencies:
postfix3-mysql x86_64 2:3.4.7-1.gf.el7 @gf-plus 64 k
Transaction Summary
Remove 1 Package (+1 Dependent package)
Installed size: 10 M
Downloading packages:
Running transaction test
Transaction test succeeded
Running transaction
Erasing : 2:postfix3-mysql-3.4.7-1.gf.el7.x86_64 1/2
Erasing : 2:postfix3-3.4.7-1.gf.el7.x86_64 2/2
warning: /etc/postfix/master.cf saved as /etc/postfix/master.cf.rpmsave
warning: /etc/postfix/main.cf saved as /etc/postfix/main.cf.rpmsave
Verifying : 2:postfix3-mysql-3.4.7-1.gf.el7.x86_64 1/2
Verifying : 2:postfix3-3.4.7-1.gf.el7.x86_64 2/2
Removed:
Dependency Removed:
Complete!
Retrieving http://mirror.ghettoforge.org/distributions/gf/gf-release-latest.gf.el7.noarch.rpm
Preparing... ########################################
Cleaning repos: base dovecot-2.3-latest epel extras gf gf-plus litespeed-mirror
: litespeed-update-mirror mariadb-mirror powerdns-mirror updates
Cleaning up list of fastest mirrors
Other repos take up 1.5 M of disk space (use --verbose for details)
Determining fastest mirrors
* epel: hk.mirrors.thegigabit.com
---> Package postfix3.x86_64 2:3.4.7-1.gf.el7 will be installed
---> Package postfix3-mysql.x86_64 2:3.4.7-1.gf.el7 will be installed
Installing:
postfix3 x86_64 2:3.4.7-1.gf.el7 gf-plus 3.1 M
postfix3-mysql x86_64 2:3.4.7-1.gf.el7 gf-plus 53 k
Transaction Summary
Install 2 Packages
Total download size: 3.2 M
Total 670 kB/s | 3.2 MB 00:04
Running transaction
Installing : 2:postfix3-3.4.7-1.gf.el7.x86_64 1/2
Installing : 2:postfix3-mysql-3.4.7-1.gf.el7.x86_64 2/2
Installed:
postfix3.x86_64 2:3.4.7-1.gf.el7 postfix3-mysql.x86_64 2:3.4.7-1.gf.el7
Complete!
[04-45-12-Fri-Oct-2019] Add group LSCPD failed, trying again, try number: 3
[04-45-12-Fri-Oct-2019] Add group LSCPD failed.
[04-45-12-Fri-Oct-2019] Add group LSCPD successful.
[04-45-12-Fri-Oct-2019] daemon-reload LSCPD successful.
[04-45-14-Fri-Oct-2019] #########################################################################
[04-45-14-Fri-Oct-2019] Restart LSCPD successful.
[04-45-14-Fri-Oct-2019] LSCPD successfully installed!
[04-45-16-Fri-Oct-2019] #########################################################################
[04-45-16-Fri-Oct-2019] python manage.py makemigrations successful.
[04-45-17-Fri-Oct-2019] #########################################################################
[04-45-17-Fri-Oct-2019] python manage.py migrate successful.
[04-45-17-Fri-Oct-2019] Upgrading Dovecot..
[04-45-39-Fri-Oct-2019] #########################################################################
[04-45-39-Fri-Oct-2019] Upgrading passwords...
[04-46-12-Fri-Oct-2019] #########################################################################
[04-46-12-Fri-Oct-2019] Dovecot upgraded.
[04-46-15-Fri-Oct-2019] #########################################################################
[04-46-15-Fri-Oct-2019] Fixing permissions..
[04-46-15-Fri-Oct-2019] chown core code successful.
[04-46-15-Fri-Oct-2019] chown core code failed, trying again, try number: 1
[04-46-15-Fri-Oct-2019] chown core code failed, trying again, try number: 2
[04-46-15-Fri-Oct-2019] chown core code failed, trying again, try number: 3
[04-46-15-Fri-Oct-2019] chown core code failed.
[04-46-22-Fri-Oct-2019] #########################################################################
[04-46-22-Fri-Oct-2019] chown core code successful.
[04-46-53-Fri-Oct-2019] #########################################################################
[04-46-53-Fri-Oct-2019] chown core code successful.
[04-46-53-Fri-Oct-2019] chmod CLPackages successful.
[04-46-53-Fri-Oct-2019] chown core code failed, trying again, try number: 1
[04-46-53-Fri-Oct-2019] chown core code failed, trying again, try number: 2
[04-46-53-Fri-Oct-2019] chown core code failed, trying again, try number: 3
[04-46-53-Fri-Oct-2019] chown core code failed.
[04-46-54-Fri-Oct-2019] #########################################################################
[04-46-54-Fri-Oct-2019] chown core code failed, trying again, try number: 2
[04-46-54-Fri-Oct-2019] chown core code failed, trying again, try number: 3
[04-46-54-Fri-Oct-2019] chown core code failed.
[04-46-54-Fri-Oct-2019] chown core code failed, trying again, try number: 1
[04-46-54-Fri-Oct-2019] Permissions updated.
[04-46-54-Fri-Oct-2019] Start LSCPD successful.
[04-46-54-Fri-Oct-2019] Upgrade Completed.
Downloading...
Requirement already satisfied: pydns in /usr/lib/python2.7/site-packages (2.3.6)
[08-53-29-Fri-Oct-2019] #########################################################################
[08-53-29-Fri-Oct-2019] remove yum-plugin-priorities successful.
[08-53-29-Fri-Oct-2019] stop lscpd successful.
[08-53-29-Fri-Oct-2019] adduser docker failed, trying again, try number: 1
[08-53-29-Fri-Oct-2019] adduser docker failed, trying again, try number: 2
[08-53-29-Fri-Oct-2019] adduser docker failed, trying again, try number: 3
[08-53-29-Fri-Oct-2019] adduser docker failed.
[08-53-29-Fri-Oct-2019] adduser docker successful.
[08-53-38-Fri-Oct-2019] #########################################################################
[08-53-38-Fri-Oct-2019] Install PyDNS successful.
[08-53-58-Fri-Oct-2019] #########################################################################
[08-53-58-Fri-Oct-2019] Download latest version successful.
[08-53-58-Fri-Oct-2019] Backing up settings file.
[08-53-58-Fri-Oct-2019] Settings file backed uRequirement already satisfied: tldextract in /usr/lib/python2.7/site-packages (2.2.1)
Requirement already satisfied: requests-file>=1.4 in /usr/lib/python2.7/site-packages (from tldextract) (1.4.3)
Requirement already satisfied: idna in /usr/lib/python2.7/site-packages (from tldextract) (2.6)
Requirement already satisfied: setuptools in /usr/lib/python2.7/site-packages (from tldextract) (0.9.8)
Requirement already satisfied: requests>=2.1.0 in /usr/lib/python2.7/site-packages (from tldextract) (2.18.4)
Requirement already satisfied: six in /usr/lib/python2.7/site-packages (from requests-file>=1.4->tldextract) (1.12.0)
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in /usr/lib/python2.7/site-packages (from requests>=2.1.0->tldextract) (3.0.4)
Requirement already satisfied: urllib3<1.23,>=1.21.1 in /usr/lib/python2.7/site-packages (from requests>=2.1.0->tldextract) (1.22)
Requirement already satisfied: certifi>=2017.4.17 in /usr/lib/python2.7/site-packages (from requests>=2.1.0->tldextract) (2019.3.9)
Requirement already satisfied: bcrypt in /usr/lib64/python2.7/site-packages (3.1.7)
Requirement already satisfied: cffi>=1.1 in /usr/lib64/python2.7/site-packages (from bcrypt) (1.12.3)
Requirement already satisfied: six>=1.4.1 in /usr/lib/python2.7/site-packages (from bcrypt) (1.12.0)
Requirement already satisfied: pycparser in /usr/lib/python2.7/site-packages (from cffi>=1.1->bcrypt) (2.19)
Nothing to do
Nothing to do
Requirement already satisfied: virtualenv in /usr/lib/python2.7/site-packages (16.4.3)
done.
done.
Installing collected packages: six, idna, pycparser, cffi, enum34, asn1crypto, ipaddress, cryptography, pyOpenSSL, urllib3, chardet, certifi, requests, setuptools, josepy, pytz, funcsigs, pbr, mock, pyRFC3339, acme, Babel, bcrypt, backports.ssl-match-hostname, jmespath, futures, docutils, python-dateutil, botocore, s3transfer, boto3, ConfigArgParse, configobj, zope.interface, zope.event, zope.component, future, parsedatetime, certbot, decorator, websocket-client, docker-pycreds, docker, Django, iniparse, IPy, MarkupSafe, Jinja2, jsonpointer, jsonpatch, kitchen, ptyprocess, pexpect, prettytable, psutil, pycurl, pydns, pygpgme, pyliblzma, pyserial, pyudev, pyxattr, PyYAML, requests-file, tldextract
done.
Nothing to do
p.
[08-54-00-Fri-Oct-2019] #########################################################################
[08-54-00-Fri-Oct-2019] Extract latest version successful.
[08-54-00-Fri-Oct-2019] Restoring settings file!
[08-54-00-Fri-Oct-2019] Settings file restored!
[08-54-00-Fri-Oct-2019] Remove old static content successful.
[08-54-12-Fri-Oct-2019] #########################################################################
[08-54-12-Fri-Oct-2019] Install tldextract successful.
[08-54-12-Fri-Oct-2019] Setting up virtual environment for CyberPanel.
[08-54-14-Fri-Oct-2019] #########################################################################
[08-54-14-Fri-Oct-2019] VirtualEnv Pre-reqs successful.
[08-54-15-Fri-Oct-2019] #########################################################################
[08-54-15-Fri-Oct-2019] VirtualEnv Pre-reqs successful.
[08-54-16-Fri-Oct-2019] #########################################################################
[08-54-16-Fri-Oct-2019] VirtualEnv Install successful.
[08-54-21-Fri-Oct-2019] #########################################################################
[08-54-21-Fri-Oct-2019] Setting up VirtualEnv [One] successful.
[08-54-54-Fri-Oct-2019] #########################################################################
[08-54-54-Fri-Oct-2019] CyberPanel requirements successful.
[08-55-00-Fri-Oct-2019] #########################################################################
[08-55-00-Fri-Oct-2019] Setting up VirtualEnv [Two] successful.
[08-55-00-Fri-Oct-2019] Virtual enviroment for CyberPanel successfully installed.
[08-55-04-Fri-Oct-2019] #########################################################################
[08-55-04-Fri-Oct-2019] Install PHP 73, 0 successful.
[08-55-04-Fri-Oct-2019] ##############################################Done.
Nothing to do
Nothing to do
[08-55-04-Fri-Oct-2019] CLI Symlink failed, trying again, try number: 1
[08-55-04-Fri-Oct-2019] CLI Symlink failed, trying again, try number: 2
[08-55-04-Fri-Oct-2019] CLI Symlink failed, trying again, try number: 3
[08-55-04-Fri-Oct-2019] CLI Symlink failed.
[08-55-04-Fri-Oct-2019] CLI Permissions successful.
[08-55-05-Fri-Oct-2019] #########################################################################
[08-55-05-Fri-Oct-2019] Starting LSCPD installation..
[08-55-06-Fri-Oct-2019] #########################################################################
[08-55-06-Fri-Oct-2019] LSCPD Pre-reqs [one] successful.
[08-55-12-Fri-Oct-2019] #########################################################################
[08-55-12-Fri-Oct-2019] LSCPD Download. successful.
[08-55-13-Fri-Oct-2019] #########################################################################
[08-55-13-Fri-Oct-2019] LSCPD Pre-reqs [two] successful.
[08-55-13-Fri-Oct-2019] Add user LSCPD failed, trying again, try number: 1
[08-55-13-Fri-Oct-2019] Add user LSCPD failed, trying again, try number: 2
[08-55-13-Fri-Oct-2019] Add user LSCPD failed, trying again, try number: 3
[08-55-13-Fri-Oct-2019] Add user LSCPD failed.
[08-55-13-Fri-Oct-2019] Add group LSCPD failed, trying again, try number: 1
[08-55-13-Fri-Oct-2019] Add group LSCPD failed, trying again, try number: 2
[08-55-13-Fri-Oct-2019] ####No changes detected
No changes detected
Removing:
Transaction Summary
Running transaction
Removed:
Dependency Removed:
Complete!
Installing:
Transaction Summary
Install 2 Packages
Total 710 kB/s | 3.2 MB 00:04
Running transaction
Installed:
Complete!
[08-55-13-Fri-Oct-2019] Add group LSCPD failed, trying again, try number: 3
[08-55-13-Fri-Oct-2019] Add group LSCPD failed.
[08-55-13-Fri-Oct-2019] Add group LSCPD successful.
[08-55-14-Fri-Oct-2019] #########################################################################
[08-55-14-Fri-Oct-2019] daemon-reload LSCPD successful.
[08-55-16-Fri-Oct-2019] #########################################################################
[08-55-16-Fri-Oct-2019] Restart LSCPD successful.
[08-55-16-Fri-Oct-2019] LSCPD successfully installed!
[08-55-17-Fri-Oct-2019] #########################################################################
[08-55-17-Fri-Oct-2019] python manage.py makemigrations successful.
[08-55-19-Fri-Oct-2019] #########################################################################
[08-55-19-Fri-Oct-2019] python manage.py migrate successful.
[08-55-19-Fri-Oct-2019] Upgrading Dovecot..
[08-55-39-Fri-Oct-2019] #########################################################################
[08-55-39-Fri-Oct-2019] Upgrading passwords...
[08-56-12-Fri-Oct-2019] #########################################################################
[08-56-12-Fri-Oct-2019] Dovecot upgraded.
[08-56-15-Fri-Oct-2019] #########################################################################
[08-56-15-Fri-Oct-2019] Fixing permissions..
[08-56-15-Fri-Oct-2019] chown core code successful.
[08-56-15-Fri-Oct-2019] chown core code failed, trying again, try number: 1
[08-56-15-Fri-Oct-2019] chown core code failed, trying again, try number: 2
[08-56-15-Fri-Oct-2019] chown core code failed, trying again, try number: 3
[08-56-15-Fri-Oct-2019] chown core code failed.
[08-56-22-Fri-Oct-2019] #########################################################################
[08-56-22-Fri-Oct-2019] chown core code successful.
[08-56-51-Fri-Oct-2019] #########################################################################
[08-56-51-Fri-Oct-2019] chown core code successful.
[08-56-52-Fri-Oct-2019] #########################################################################
[08-56-52-Fri-Oct-2019] chown core code successful.
[08-56-52-Fri-Oct-2019] chmod CLPackages successful.
[08-56-52-Fri-Oct-2019] chown core code failed, trying again, try number: 1
[08-56-52-Fri-Oct-2019] chown core code failed, trying again, try number: 2
[08-56-52-Fri-Oct-2019] chown core code failed, trying again, try number: 3
[08-56-52-Fri-Oct-2019] chown core code failed.
[08-56-52-Fri-Oct-2019] Permissions updated.
[08-56-53-Fri-Oct-2019] #########################################################################
[08-56-53-Fri-Oct-2019] Start LSCPD successful.
[08-56-53-Fri-Oct-2019] Upgrade Completed.
Similar cases. Need help!
Similar cases. Need help! Second that…
curl -I -XGET -k https://127.0.0.1:8090
curl: (35) SSL received a record that exceeded the maximum permissible length.
What OLS version has been installed? What is OLS?
What browser are you using? Chrome
Are you using a valid ssl certificate or self signed? Was using valid ssl certificate but after update its gone.
Are you using cloudflare? Not using Cloudflare
What OS are you using? Centos 7
I get the same error too after upgrade
