Thanks for clarifying which logs to look for - I wouldn’t have known, as I am not aware if my problem is with Dovecot or Rainloop or what.
Mar 10 15:01:52 localhost postfix/smtpd[57865]: fatal: no SASL authentication mechanisms
Perhaps this is an issue with postfix? How am I supposed to do this?
postfix conf
postconf: warning: /etc/postfix/master.cf: undefined parameter: mua_sender_restrictions
postconf: warning: /etc/postfix/master.cf: undefined parameter: mua_client_restrictions
postconf: warning: /etc/postfix/master.cf: undefined parameter: mua_helo_restrictions
postconf: warning: /etc/postfix/main.cf: undefined parameter: virtual_mailbox_limit_maps
alias_database = hash:/etc/aliases
alias_maps = hash:/etc/aliases
broken_sasl_auth_clients = yes
command_directory = /usr/sbin
daemon_directory = /usr/lib/postfix/sbin
data_directory = /var/lib/postfix
debug_peer_level = 2
debugger_command = PATH=/bin:/usr/bin:/usr/local/bin:/usr/X11R6/bin ddd $daemon_directory/$process_name $process_id & sleep 5
dovecot_destination_recipient_limit = 1
html_directory = no
inet_interfaces = all
inet_protocols = all
mail_owner = postfix
mailq_path = /usr/bin/mailq.postfix
manpage_directory = /usr/share/man
message_size_limit = 30720000
milter_default_action = accept
mydestination = localhost, localhost.localdomain
myhostname = localhost
mynetworks = 127.0.0.0/8
newaliases_path = /usr/bin/newaliases.postfix
non_smtpd_milters = $smtpd_milters
proxy_read_maps = $local_recipient_maps $mydestination $virtual_alias_maps $virtual_alias_domains $virtual_mailbox_maps $virtual_mailbox_domains $relay_recipient_maps $relay_domains $canonical_maps $sender_canonical_maps $recipient_canonical_maps $relocated_maps $transport_maps $mynetworks $virtual_mailbox_limit_maps
queue_directory = /var/spool/postfix
readme_directory = /usr/share/doc/postfix-2.10.1/README_FILES
sample_directory = /usr/share/doc/postfix-2.10.1/samples
sendmail_path = /usr/sbin/sendmail.postfix
setgid_group = postdrop
smtp_tls_security_level = may
smtpd_data_restrictions = check_policy_service unix:/var/log/policyServerSocket
smtpd_milters = inet:127.0.0.1:8891
smtpd_policy_service_default_action = DUNNO
smtpd_recipient_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination
smtpd_sasl_auth_enable = yes
smtpd_sasl_authenticated_header = yes
smtpd_sasl_path = private/auth
smtpd_sasl_type = dovecot
smtpd_tls_cert_file = /etc/pki/dovecot/certs/dovecot.pem
smtpd_tls_key_file = /etc/pki/dovecot/private/dovecot.pem
smtpd_use_tls = yes
tls_server_sni_maps = hash:/etc/postfix/vmail_ssl.map
unknown_local_recipient_reject_code = 550
virtual_alias_domains =
virtual_alias_maps = proxy:mysql:/etc/postfix/mysql-virtual_forwardings.cf, mysql:/etc/postfix/mysql-virtual_email2email.cf
virtual_gid_maps = static:5000
virtual_mailbox_base = /home/vmail
virtual_mailbox_domains = proxy:mysql:/etc/postfix/mysql-virtual_domains.cf
virtual_mailbox_maps = proxy:mysql:/etc/postfix/mysql-virtual_mailboxes.cf
virtual_transport = dovecot
virtual_uid_maps = static:5000
postconf: warning: /etc/postfix/main.cf: unused parameter: virtual_create_maildirsize=yes
postconf: warning: /etc/postfix/main.cf: unused parameter: virtual_maildir_extended=yes
