hello, I have such a problem that when I install cyberpanel everything works. Installs Wordpress etc, everything works. when I do a Vps reset then the cyberpanel or my website no longer works for me. I need to re-install the system and cyberpanel. What is the problem?
CyberPanel at port 8090 does not work or your normal sites? Or none of them works?
Nothing works at all after Vps restart with cyber panel. I can log in normally by SSH. the site does not work and the cyberpanel on port 8090 also does not.
it looks as if the cyberpanel did not turn on after reboot.
I still have the inscription the page is unreachable.
try
systemctl stop firewalld
It works. With each VPS restart I will be forced to turn off the firewall?
It should not be like that. I will investigate further.
Okey, thanks for help!
