I just installed vps with OS centos 7, and installed cyberpanel. after the installation process is complete, I successfully login to cyberpanel. however, after I restarted the VPS. cyberpanel cannot function. I can’t even log in to Putty or ping the server.
If you login via console virtual machine is booting fine? Can you log into SSH?
Can you check if network is working?
[root@server /]# service network status
Configured devices:
lo venet0
Currently active devices:
lo
[root@server /]# service network restart
Restarting network (via systemctl): Job for network.service canceled.
[FAILED]
[root@server /]# ip route show
systemd-vconsole-setup.service loaded failed failed Setup Virtual Console
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
3 loaded units listed. Pass --all to see loaded but inactive units, too.
To show all installed unit files use ‘systemctl list-unit-files’.
