CyberPanel Community
Cyberpanel not starting up
RN
Rohir N #1
Cyberpanel not starting up neither update get done. below is the log:
[root@server local]# service lscpd restart
Redirecting to /bin/systemctl restart lscpd.service
Job for lscpd.service failed because the control process exited with error code.
See “C” and “journalctl -xe” for details.
Upon further : systemctl status lscpd.service below is the error:
[root@server local]# systemctl status lscpd.service
● lscpd.service - LSCPD Daemon
Loaded: loaded (/etc/systemd/system/lscpd.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Fri 2023-02-03 00:28:28 IST; 1min 23s ago
Process: 67282 ExecStart=/usr/local/lscp/bin/lscpdctrl start (code=exited, status=203/EXEC)
Feb 03 00:28:28 server.integratex.tech systemd[1]: Starting LSCPD Daemon…
Feb 03 00:28:28 server.integratex.tech systemd[1]: lscpd.service: Control process exited, code=exited status=203
Feb 03 00:28:28 server.integratex.tech systemd[1]: lscpd.service: Failed with result ‘exit-code’.
Feb 03 00:28:28 server.integratex.tech systemd[1]: Failed to start LSCPD Daemon.
Kindly help to fix this
jo
josephgodwinke #2
Welcome and Happy New Year @rohir_coderix
Post the results of this command
# show me logs for my service (please do not copy the $ sign)
$ journalctl -u lscpd
RN
Rohir N #3
– Logs begin at Fri 2023-02-03 00:05:53 IST, end at Fri 2023-02-03 15:23:54 IST. –
Feb 03 00:06:00 server.integratex.tech systemd[1]: Starting LSCPD Daemon…
Feb 03 00:06:00 server.integratex.tech systemd[1]: lscpd.service: Control process exited, code=exited status=203
Feb 03 00:06:00 server.integratex.tech systemd[1]: lscpd.service: Failed with result ‘exit-code’.
Feb 03 00:06:00 server.integratex.tech systemd[1]: Failed to start LSCPD Daemon.
Feb 03 00:06:49 server.integratex.tech systemd[1]: Starting LSCPD Daemon…
Feb 03 00:06:49 server.integratex.tech systemd[1]: lscpd.service: Control process exited, code=exited status=203
Feb 03 00:06:49 server.integratex.tech systemd[1]: lscpd.service: Failed with result ‘exit-code’.
Feb 03 00:06:49 server.integratex.tech systemd[1]: Failed to start LSCPD Daemon.
Feb 03 00:10:10 server.integratex.tech systemd[1]: Starting LSCPD Daemon…
Feb 03 00:10:10 server.integratex.tech systemd[1]: lscpd.service: Control process exited, code=exited status=203
Feb 03 00:10:10 server.integratex.tech systemd[1]: lscpd.service: Failed with result ‘exit-code’.
Feb 03 00:10:10 server.integratex.tech systemd[1]: Failed to start LSCPD Daemon.
Feb 03 00:10:19 server.integratex.tech systemd[1]: Starting LSCPD Daemon…
Feb 03 00:10:19 server.integratex.tech systemd[1]: lscpd.service: Control process exited, code=exited status=203
Feb 03 00:10:19 server.integratex.tech systemd[1]: lscpd.service: Failed with result ‘exit-code’.
Feb 03 00:10:19 server.integratex.tech systemd[1]: Failed to start LSCPD Daemon.
Feb 03 00:17:46 server.integratex.tech systemd[1]: Starting LSCPD Daemon…
Feb 03 00:17:47 server.integratex.tech systemd[1]: lscpd.service: Control process exited, code=exited status=203
Feb 03 00:17:47 server.integratex.tech systemd[1]: lscpd.service: Failed with result ‘exit-code’.
Feb 03 00:17:47 server.integratex.tech systemd[1]: Failed to start LSCPD Daemon.
Feb 03 00:17:52 server.integratex.tech systemd[1]: Starting LSCPD Daemon…
Feb 03 00:17:52 server.integratex.tech systemd[1]: lscpd.service: Control process exited, code=exited status=203
Feb 03 00:17:52 server.integratex.tech systemd[1]: lscpd.service: Failed with result ‘exit-code’.
Feb 03 00:17:52 server.integratex.tech systemd[1]: Failed to start LSCPD Daemon.
Feb 03 00:23:06 server.integratex.tech systemd[1]: Starting LSCPD Daemon…
jo
josephgodwinke #4
$  ls /usr/local/lscp/bin/
RN
Rohir N #5
ls: cannot access ‘/usr/local/lscp/bin/’: No such file or directory
THIS IS THE ERROR. WHAT CAN BE CAUSE
@usmannasir @josephgodwinke This happened after last Update of CyberPanel. /usr/local directory was missing. Thats very sad :frowning:
jo
josephgodwinke #6
I recommend you still run an upgrade still or if you have a snapshot of your server run it to an earlier snapshot and try again to see if issue persists.
