Failed to load resource: the server responded with a status of 404 (Not Found)
jquery-core.min.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
(index):34 Uncaught ReferenceError: $ is not defined
at (index):34
loading.gif:1 Failed to load resource: the server responded with a status of 404 (Not Found)
2login-systen.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
angular.js:4957 Uncaught Error: [$injector:modulerr] http://errors.angularjs.org/1.6.5/$injector/modulerr?p0=loginSystem&p1=Error%3A%20%5B%24injector%3Anomod%5D%20http%3A%2F%2Ferrors.angularjs.org%2F1.6.5%2F%24injector%2Fnomod%3Fp0%3DloginSystem%0A%20%20%20%20at%20https%3A%2F%2Fcode.angularjs.org%2F1.6.5%2Fangular.min.js%3A7%3A76%0A%20%20%20%20at%20https%3A%2F%2Fcode.angularjs.org%2F1.6.5%2Fangular.min.js%3A26%3A408%0A%20%20%20%20at%20b%20(https%3A%2F%2Fcode.angularjs.org%2F1.6.5%2Fangular.min.js%3A25%3A439)%0A%20%20%20%20at%20https%3A%2F%2Fcode.angularjs.org%2F1.6.5%2Fangular.min.js%3A26%3A182%0A%20%20%20%20at%20https%3A%2F%2Fcode.angularjs.org%2F1.6.5%2Fangular.min.js%3A42%3A290%0A%20%20%20%20at%20p%20(https%3A%2F%2Fcode.angularjs.org%2F1.6.5%2Fangular.min.js%3A8%3A7)%0A%20%20%20%20at%20g%20(https%3A%2F%2Fcode.angularjs.org%2F1.6.5%2Fangular.min.js%3A42%3A138)%0A%20%20%20%20at%20gb%20(https%3A%2F%2Fcode.angularjs.org%2F1.6.5%2Fangular.min.js%3A46%3A251)%0A%20%20%20%20at%20c%20(https%3A%2F%2Fcode.angularjs.org%2F1.6.5%2Fangular.min.js%3A22%3A19)%0A%20%20%20%20at%20Uc%20(https%3A%2F%2Fcode.angularjs.org%2F1.6.5%2Fangular.min.js%3A22%3A332)
at angular.js:88
at angular.js:4957
at p (angular.js:410)
at g (angular.js:4917)
at gb (angular.js:4839)
at c (angular.js:1949)
at Uc (angular.js:1970)
at xe (angular.js:1855)
at angular.js:33826
at HTMLDocument.b (angular.js:3468)
allCss.css:1 Failed to load resource: the server responded with a status of 404 (Not Found)
What is the output of
ps aux | grep lscpd
root 6962 0.0 0.0 41540 1568 ? S 07:29 0:00 lscpd (lscpd - main)
nobody 6965 0.0 0.1 42024 3464 ? S 07:29 0:01 lscpd (lscpd - #01)
nobody 6966 0.0 0.1 42024 3588 ? S 07:29 0:01 lscpd (lscpd - #02)
root 13833 0.0 0.0 112712 980 pts/0 S+ 08:03 0:00 grep --color=auto lscpd
Do
chown -R nobody:nobody /usr/local/lscp/cyberpanel
Solved Thks,
