any help would be appreciated…
I do not have an unusual setup…I installed CP in july and have used it ever since.
1). I access the CP by server.example.com:8090…where server.example.com is the hostname.
2). The SSL cert for server.example.com has been updated since July and does not expire for a few months.
3). The SSL cert for server.example.com supplied by server.example.com:8090 (cyberpanel) is the old original cert from the first install which IS expired.
I have checked with fresh browsers / multiple PCs…this is not some odd cache issue as I first thought. I have restarted LSWS and the cyberpanel.
I am on Centos and have CP 1.9…by I don’t think that is the issue.
Was the old Cert copied to the Cyberpanel directory…I have yet to find it?
RDL
