I use this command:
Where should I start?
Error Message:
[02.13.2026_20-39-17] #########################################################################
[02.13.2026_20-39-17] [ERROR] We are not able to run /usr/local/CyberPanel/bin/python manage.py migrate return code: 1. Fat
al error, see /var/log/installLogs.txt for full details.
Oops, something went wrong...
Starting installation..,1
Initialization completed..,2
Setting up repositories...,1
Installing necessary components..,3
Installing required virtual environment,3
Installing requirments..,3
Getting CyberPanel code..,4
Necessary components installed..,5
Setting up system tweak...,20
Starting main installation..,30
[02.13.2026_20-33-34] Starting CyberPanel installation..,10
[02.13.2026_20-33-45] [ERROR] setup_account_cyberpanel. 71,10
[02.13.2026_20-33-54] Installing LiteSpeed Web server,40
[02.13.2026_20-34-53] Installing Optimized PHPs..,50
[02.13.2026_20-35-07] Installing Sieve for email filtering..,55
[02.13.2026_20-35-10] [ERROR] No module named 'plogical' [installSieve],55
[02.13.2026_20-35-10] Installing MySQL,60
[02.13.2026_20-36-00] Pure-FTPd enabled but not started - waiting for Django migrations,60
[02.13.2026_20-36-12] PowerDNS enabled but not started - waiting for Django migrations,60
[02.13.2026_20-36-12] [setupPHPSymlink] PHP 8.4 not found, ensuring it's installed...
[02.13.2026_20-36-13] [ERROR] [Errno 2] No such file or directory: 'DEBIAN_FRONTEND=noninteractive' [setupPHPSymlink], ensu>
[02.13.2026_20-36-16] [ERROR] fix_selinux_issue problem, ensuring it's installed...
[02.13.2026_20-37-06] Setting up authentication for Postfix and Dovecot..., ensuring it's installed...
[02.13.2026_20-37-07] Authentication for Postfix and Dovecot set., ensuring it's installed...
[02.13.2026_20-37-07] Configuring postfix and dovecot..., ensuring it's installed...
[02.13.2026_20-37-20] Postfix and Dovecot configured, ensuring it's installed...
[02.13.2026_20-38-16] FirewallD installed and configured!, ensuring it's installed...
[02.13.2026_20-38-53] Updating /root/.my.cnf!, ensuring it's installed...
[02.13.2026_20-38-53] Generating secure environment configuration!, ensuring it's installed...
[02.13.2026_20-38-54] ✓ Secure .env file generated successfully, ensuring it's installed...
[02.13.2026_20-38-54] ✓ Credentials backup created for recovery, ensuring it's installed...
[02.13.2026_20-38-54] Environment configuration generated successfully!, ensuring it's installed...
[02.13.2026_20-38-55] settings.py updated!, ensuring it's installed...
Oops, something went wrong... [404]
