oreana
October 11, 2021, 5:13pm
1
Provider: Oracle Cloud
Virtualization Type: VPS
System: Ubuntu 20.04
Installation option:
OLS or Enterprise?
OLS
official
no
Install LiteSpeed Memcached?
no
Install Memcached?
no
no
Install Redis?
yes
Problem:
[10.11.2021_16-44-44] [ERROR] We are not able to run apt-get -y install openlitespeed return code: 100. Fatal error, see /var/log/installLogs.txt for full details.
I tried re-install but still happens the same again and again.
oreana
October 12, 2021, 3:05pm
2
I’m facing issue while installation of cyber panel.
Error is -
Reading package lists… Done
Building dependency tree
Reading state information… Done
E: Unable to locate package openlitespeed
[10.12.2021_15-01-40] ########################################################## ###############
[10.12.2021_15-01-40] Running apt-get -y install openlitespeed failed. Running a gain, try number 3
[10.12.2021_15-01-40] [ERROR] We are not able to run apt-get -y install openlite speed return code: 100. Fatal error, see /var/log/installLogs.txt for full deta ils.
Oops, something went wrong…
and its stope process ahead.
please help.
Rahul
October 14, 2021, 5:00pm
3
I also face pip install --default-timeout=3600 virtualenv==16.7.9 has failed for 49 times
in Centos7:
Collecting decorator==3.4.0
Using cached decorator-3.4.0.tar.gz (30 kB)
Preparing metadata (setup.py) … error
command: /usr/local/CyberPanel/bin/python3 -c ‘import io, os, sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-ht97s020/decorator_f44e397aec204694b0ef75de5a2cf012/setup.py’“'”‘; file =’“'”‘/tmp/pip-install-ht97s020/decorator_f44e397aec204694b0ef75de5a2cf012/setup.py’“'”‘;f = getattr(tokenize, ‘"’“‘open’”’“‘, open)(file ) if os.path.exists(file ) else io.StringIO(’”‘“‘from setuptools import setup; setup()’”’“‘);code = f.read().replace(’”‘"’\r
‘"’“');f.close();exec(compile(code, file , '”‘“‘exec’”’"‘))’ egg_info --egg-base /tmp/pip-pip-egg-info-k66g2dkq
cwd: /tmp/pip-install-ht97s020/decorator_f44e397aec204694b0ef75de5a2cf012/
Complete output (1 lines):
error in decorator setup command: use_2to3 is invalid.
WARNING: Discarding https://files.pythonhosted.org/packages/f3/26/876d492f2394f29401eb652ddfa53dec2bc8721861c7fe0dce1b5d0d2b6a/decorator-3.4.0.tar.gz#sha256=c20b404cbb7ee5cebd506688e0114e3cd76f5ce233805a51f36e1a7988d9d783 (from Links for decorator ). Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
ERROR: Could not find a version that satisfies the requirement decorator==3.4.0 (from versions: 3.3.1, 3.3.2, 3.3.3, 3.4.0, 3.4.2, 4.0.0, 4.0.1, 4.0.2, 4.0.3, 4.0.4, 4.0.6, 4.0.8, 4.0.9, 4.0.10, 4.0.11, 4.1.0, 4.1.1, 4.1.2, 4.2.1, 4.3.0, 4.3.1, 4.3.2, 4.4.0, 4.4.1, 4.4.2, 5.0.3, 5.0.4, 5.0.5, 5.0.6, 5.0.7, 5.0.8, 5.0.9, 5.1.0)
ERROR: No matching distribution found for decorator==3.4.0
pip install --default-timeout=3600 -r /usr/local/requirments.txt has failed for 49 times
Wait for 3 seconds and try again…
I have this error on Oracle cloud - Ubuntu 20.04
(23) Failed writing body
I solved my problem using "sudo su - " then run the scrip to install.
Oracle Cloud - Ubuntu 20.04
I am getting this error in oracle cloud.
x86_64 system is required…
which image and shape did you use?
Make sure you are using AMD hardware (1 CPU and 1 GB of RAM) and not the Ampere one (allows 4 Cores and 24 GB of RAM). Openlitespeed for some reason doesn’t work on 32 bit Raspberry Pi or Arm based machines
pras672
December 16, 2021, 12:30pm
9
@CyberPanel is there any plan to working on cyberpanel to support ARM processer because now days Oracle giving VPS for free so more number people will use it.???
pras672
December 16, 2021, 12:32pm
10
thats AMD server right? AMR server wont support cyberpanel.
Please create a feature request for this here
Feature requests can be created here.
system
Closed
December 16, 2021, 4:49pm
12
