I am writing through translation
Towards the end of the installation, it gives the following error.
Every time it gave an error, I deleted the vps and installed it again. gives the same error.
setup failed
Please explain in a simple way what I have to do.
I do not know much about these issues
vps system
centos7 64bit
vps provider company = contabo.com
6 core processor
16 Gb Ram
[08.16.2020_18-47-01] #########################################################################
[08.16.2020_18-47-01] Running /usr/local/CyberPanel/bin/python manage.py makemigrations failed. Running again, try number 3
[08.16.2020_18-47-01] [ERROR] We are not able to run /usr/local/CyberPanel/bin/python manage.py makemigrations return code: 1. Fatal error, see /var/log/installLogs.txt for full details.
buradan sonrası, ssh üzerinden aldığım ekran bilgisi.
[08.16.2020_18-46-52] #########################################################################
[08.16.2020_18-46-52] Successfully ran: ssh-keygen -f /root/.ssh/cyberpanel -t rsa -N ‘’.
[08.16.2020_18-46-52] Running: echo downloaded
downloaded
[08.16.2020_18-46-52] Successfully ran: echo downloaded.
[08.16.2020_18-46-52] Running: sed -i ‘s|localhost|vps.biliyoo.com|g’ /usr/local/CyberCP/CyberCP/settings.py
[08.16.2020_18-46-52] Successfully ran: sed -i ‘s|localhost|vps.biliyoo.com|g’ /usr/local/CyberCP/CyberCP/settings.py.
[08.16.2020_18-46-52] Running: sed -i ‘s|‘USER’: ‘root’,|‘USER’: ‘admin’,|g’ /usr/local/CyberCP/CyberCP/settings.py
[08.16.2020_18-46-52] Successfully ran: sed -i ‘s|‘USER’: ‘root’,|‘USER’: ‘admin’,|g’ /usr/local/CyberCP/CyberCP/settings.py.
[08.16.2020_18-46-52] Running: sed -i ‘s|‘PORT’:’‘|‘PORT’:‘8090’|g’ /usr/local/CyberCP/CyberCP/settings.py
[08.16.2020_18-46-52] Successfully ran: sed -i ‘s|‘PORT’:’‘|‘PORT’:‘8090’|g’ /usr/local/CyberCP/CyberCP/settings.py.
[08.16.2020_18-46-52] Running: /usr/local/CyberPanel/bin/python manage.py makemigrations
File “/usr/local/CyberPanel/lib/python3.6/site-packages/django/db/backends/base/base.py”, line 220, in ensure_connection
self.connect()
File “/usr/local/CyberPanel/lib/python3.6/site-packages/django/utils/asyncio.py”, line 26, in inner
return func(*args, **kwargs)
File “/usr/local/CyberPanel/lib/python3.6/site-packages/django/db/backends/base/base.py”, line 197, in connect
File “/usr/local/CyberPanel/lib/python3.6/site-packages/django/db/backends/mysql/base.py”, line 233, in get_new_connection
return Database.connect(**conn_params)
File “/usr/local/CyberPanel/lib/python3.6/site-packages/MySQLdb/init.py”, line 84, in Connect
File “/usr/local/CyberPanel/lib/python3.6/site-packages/MySQLdb/connections.py”, line 179, in init
super(Connection, self).init(*args, **kwargs2)
MySQLdb._exceptions.OperationalError: (2005, “Unknown MySQL server host ‘vps.biliyoo.com’ (-2)”)
The above exception was the direct cause of the following exception:
File “manage.py”, line 22, in
File “/usr/local/CyberPanel/lib/python3.6/site-packages/django/core/management/init.py”, line 401, in execute_from_command_line
utility.execute()
File “/usr/local/CyberPanel/lib/python3.6/site-packages/django/core/management/init.py”, line 395, in execute
File “/usr/local/CyberPanel/lib/python3.6/site-packages/django/core/management/base.py”, line 328, in run_from_argv
File “/usr/local/CyberPanel/lib/python3.6/site-packages/django/core/management/base.py”, line 366, in execute
self.check()
File “/usr/local/CyberPanel/lib/python3.6/site-packages/django/core/management/base.py”, line 395, in check
include_deployment_checks=include_deployment_checks,
File “/usr/local/CyberPanel/lib/python3.6/site-packages/django/core/management/base.py”, line 382, in _run_checks
return checks.run_checks(**kwargs)
File “/usr/local/CyberPanel/lib/python3.6/site-packages/django/core/checks/registry.py”, line 72, in run_checks
new_errors = check(app_configs=app_configs)
File “/usr/local/CyberPanel/lib/python3.6/site-packages/django/core/checks/model_checks.py”, line 34, in check_all_models
errors.extend(model.check(**kwargs))
File “/usr/local/CyberPanel/lib/python3.6/site-packages/django/db/models/base.py”, line 1274, in check
*cls._check_constraints(),
File “/usr/local/CyberPanel/lib/python3.6/site-packages/django/db/models/base.py”, line 1840, in _check_constraints
connection.features.supports_table_check_constraints or
File “/usr/local/CyberPanel/lib/python3.6/site-packages/django/utils/functional.py”, line 48, in get
File “/usr/local/CyberPanel/lib/python3.6/site-packages/django/db/backends/mysql/features.py”, line 93, in supports_column_check_constraints
if self.connection.mysql_is_mariadb:
File “/usr/local/CyberPanel/lib/python3.6/site-packages/django/db/backends/mysql/base.py”, line 363, in mysql_is_mariadb
return ‘mariadb’ in self.mysql_server_info.lower()
File “/usr/local/CyberPanel/lib/python3.6/site-packages/django/db/backends/mysql/base.py”, line 350, in mysql_server_info
File “/usr/lib64/python3.6/contextlib.py”, line 81, in enter
return next(self.gen)
File “/usr/local/CyberPanel/lib/python3.6/site-packages/django/db/backends/base/base.py”, line 604, in temporary_connection
with self.cursor() as cursor:
File “/usr/local/CyberPanel/lib/python3.6/site-packages/django/db/backends/base/base.py”, line 260, in cursor
return self._cursor()
File “/usr/local/CyberPanel/lib/python3.6/site-packages/django/db/backends/base/base.py”, line 236, in _cursor
self.ensure_connection()
self.connect()
File “/usr/local/CyberPanel/lib/python3.6/site-packages/django/db/utils.py”, line 90, in exit
raise dj_exc_value.with_traceback(traceback) from exc_value
self.connect()
django.db.utils.OperationalError: (2005, “Unknown MySQL server host ‘vps.biliyoo.com’ (-2)”)
[08.16.2020_18-46-56] #########################################################################
[08.16.2020_18-46-56] Running /usr/local/CyberPanel/bin/python manage.py makemigrations failed. Running again, try number 1
self.connect()
utility.execute()
self.check()
self.connect()
self.connect()
[08.16.2020_18-46-58] #########################################################################
[08.16.2020_18-46-58] Running /usr/local/CyberPanel/bin/python manage.py makemigrations failed. Running again, try number 2
self.connect()
utility.execute()
self.check()
self.connect()
self.connect()
Oops, something went wrong…
[root@vmi149483 ~]#
