Cyberpanel custom theme?
I want to make a custom theme for Cyberpanel. Should I make a new branch on GitHub or just contribute on master?
I like to make a new theme for File Manager first. It should look like Cpanel which I think very clean and easy to use.
Thank you.
You can fork and then create a new branch (we can merge later), plus making new UI for File Manager will be very easy, as you only need to modify the single file.
The file is located here: cyberpanel/index.html at master · usmannasir/cyberpanel · GitHub
Rest will be easy when you get some hands-on.
