This is what I am got when searching the forum. However if you read the openlitespeed documentation it states:
- ARM CPU may work if you can compile OLS yourself from the source successfully but you can not use binary installation or use repository to install at all.
Source: Minimum System Requirements – OpenLiteSpeed
So why doesn’t CyberPanel support the ARM processor?
