cyber panel wordpress installation error heeeelp
why this feature does not work
no one answers why
I can not access those links above.
broken links repaired
https://resmim.net/f/9zDuXX.png why this feature does not work https://resmim.net/f/k5sc8r.png
happened same to me this process is not automated so you have to go to your filemanager>public_html and delete index.php and now install wordpress
if you are trying to install in a directory then empty any content in the directory and then proceed with the installation
Correct izaan!
There a default index file inside, you can ignore the .welknown file…
